JamieP Posted June 8, 2010 Share Posted June 8, 2010 Although im not mad on carbon stuff the filler on my my dash2 pod keeps sinking back and it looks aweful, thinking this might be a decent solution? Watch the video http://www.carbonmods.co.uk/Products/Carbon-Fibre-Skinning-Starter-Kit__CMCFSK300.aspx Link to comment Share on other sites More sharing options...
mwilkinson Posted June 8, 2010 Share Posted June 8, 2010 Came up with an error when I just tried this? - The link that is. Link to comment Share on other sites More sharing options...
heckler Posted June 8, 2010 Share Posted June 8, 2010 Although im not mad on carbon stuff the filler on my my dash2 pod keeps sinking back and it looks aweful, thinking this might be a decent solution? Watch the video http://www.carbonmods.co.uk/Products/Carbon-Fibre-Skinning-Starter-Kit__CMCFSK300.aspx Havent tried it, but have been very tempted to get it... Link to comment Share on other sites More sharing options...
Geo Posted June 8, 2010 Share Posted June 8, 2010 Looks good. But im guessing you need a few hours to kill to do this? Link to comment Share on other sites More sharing options...
JamieP Posted June 8, 2010 Author Share Posted June 8, 2010 Looks good. But im guessing you need a few hours to kill to do this? Its going to take a couple of days by the look of it, i like a challenge though, stuff it, im gonna order a kit, will post results with all my fingers stuck together:D Link to comment Share on other sites More sharing options...
sdistc Posted June 8, 2010 Share Posted June 8, 2010 Funny you should mention this - I just watched their video tutorial yesterday 6rTWaV1imzs Link to comment Share on other sites More sharing options...
Brazil Posted June 8, 2010 Share Posted June 8, 2010 Just watched the vid on that site..! Really good finish on those pieces..! It appears easier to work with then fibre glass..! Link to comment Share on other sites More sharing options...
Suprab1 Posted June 8, 2010 Share Posted June 8, 2010 Interested in the results Jamie, even if its just stuck fingers Link to comment Share on other sites More sharing options...
Stevo Posted June 8, 2010 Share Posted June 8, 2010 Yep - have got a few bits 'n' bobs on the go as we speak. Have just finished one of a set of wing mirrors (just started the second one). It is pretty hard to get a good finish in the clear resin without any bubbles and requires a lot of patience and time. My tips would be: 1. Apply resin thinly with a soft haired brush (good quality so the hairs don't detach and end up in the resin). I bought some decent one from a model/art shop rather than use their bristle ones. 2. Make sure you get the Hardener:Resin ration spot on! Too much hardener will leave the resin coat with a 'milky' look to it. 3. Ensure the temperature of whatever room you are doing it in is somewhere between 20-21 deg C. constantly. 4. Allow 24hrs drying time between coats (despite what the tutorial says) 5. The base colour of whatever you're applying it to ought to be black. The resin basecoat is not opaque - therefore, light colours not only show through the basecoat but also through the weave in the carbon! Spray item with black plastic primer first. 6. I finish off with 2000 then 3000 grit wet and dry (they only supply upto 1200 in the kit) Thats all I can think of at the minute. I will say that the overall finish is awesome! It looks like I've bought a carbon mirror basically. Will post up some pics of the mirror tomorrow when I get a chance. Link to comment Share on other sites More sharing options...
JamieP Posted June 8, 2010 Author Share Posted June 8, 2010 Thanks for the tips Stevo. Link to comment Share on other sites More sharing options...
Stevo Posted June 8, 2010 Share Posted June 8, 2010 Oh and... 7. If you use a hairdryer to help with some of the smaller air bubbles like they suggest, make sure you let it blow for a few minutes away from the item. Amazing how much dust etc accumulates and blows out when you turn it on. 8. Don't hold it too close (50cm min) or in one place for too long. If you've got the consistency of the resin correct it will create a ripple - meaning more work for you at the flatting back stage Link to comment Share on other sites More sharing options...
Nick Posted June 8, 2010 Share Posted June 8, 2010 There's a company called Robson Leather in Japan that will carbon overlay parts for you. They're bloody expensive, but the finish is by *far* the best I've seen. I had my injector cover done. If it doesn't work out and you want their details drop me a PM. Link to comment Share on other sites More sharing options...
TLicense Posted June 8, 2010 Share Posted June 8, 2010 It's your basic wet lay-up using the existing component as the mould. He seems to get a good finish on those bits he's done, but having done plenty of wet lay-up in the past, I can tell you it's not half as easy as he makes it look. We tend to use pre-preg which has the resin already on the resin (and in a tacky state) so we just have to lay it onto the component, stick it in an oven to get the resin to flow evenly over the part and jobs a good 'un. Have often thought about scanning in the dash panels and making some proper CFRP panels but it would cost an absolute bomb, so this may well be a reasonable alternative. Let us know how you get on Jamie. Link to comment Share on other sites More sharing options...
Stevo Posted June 9, 2010 Share Posted June 9, 2010 Ok here are the pics of the mirror I've skinned. Due to having to use the flash on the camera, the harshness of the white light hasn't done it justice. Think I'll photograph the process from start to finish on the next mirror and post it up here if anyone is interested. Link to comment Share on other sites More sharing options...
JamieP Posted June 9, 2010 Author Share Posted June 9, 2010 Thats come out well. Link to comment Share on other sites More sharing options...
AndyT Posted June 9, 2010 Share Posted June 9, 2010 Ok here are the pics of the mirror I've skinned. Due to having to use the flash on the camera, the harshness of the white light hasn't done it justice. Think I'll photograph the process from start to finish on the next mirror and post it up here if anyone is interested. Too right we're interested Stevo. That looks like a great finish. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 9, 2010 Share Posted June 9, 2010 yeah them mirrors look cool mate well done, good luck jamie!! Link to comment Share on other sites More sharing options...
JamieP Posted June 12, 2010 Author Share Posted June 12, 2010 Not sure i have the patients for this, think i put the overlay on to soon and its starting to unpeel now i have put on the clearcoat:( might be dropping this to Noel at Nur motorsport to sort out for me. Link to comment Share on other sites More sharing options...
Paul Posted June 12, 2010 Share Posted June 12, 2010 Only problem with this is it can become loose over time. I overlayed my inlet scoop a few years back and it looked really good, due to the different expansion rates of the resin and the original plastic base the two have now become seperated. I guess I could glue them together but at the moment the shape stops them finally falling apart. Link to comment Share on other sites More sharing options...
Dyer864 Posted June 12, 2010 Share Posted June 12, 2010 Yeah i was looking at this kit a while back, and the mirrors is what i wanted to do ! Looks like a good job from those pics steveo, very interseted if you got a bit of spare time on your hands, even got a set of spare mirrors ready to go ! Link to comment Share on other sites More sharing options...
colsoop Posted June 12, 2010 Share Posted June 12, 2010 I have done something similar in the past albeit by buying the various bits and bobs. Have a search for a post by Paul. He did this a few years back and got a good finish. Edit: here is the link: http://www.mkivsupra.net/vbb/showthread.php?t=69158&highlight=carbon Link to comment Share on other sites More sharing options...
