More power
Guest sidewaysphoenix
Hi Guys
Without stating the obvious and buying a TT, is the anything that can be done to the NA to get more go from it?
:search:
On the verge of swapping for a r33 GTST ( dont blast me ) but love the supto much HELP....
blimey sounds tricky to extract more power from the NA, need to find someone who wants to downgrade ideally i think.... Yeah thats gonna happen.
strange you have just posted this... only just got back from driving my mate to pick up his r33 gtst in the supra (NA). Was a really fun drive back :)! Even though the skyline had the performance over the NA, i'd rather replace the engine to a TT and gearbox to a V160 then sell. So, erm im waffling but yeah... Think as rob_boi has mentioned, easiest way forward (literally) is maybe considering a engine transplant :)!
only other way of making a more powerful NA.. build the shit out of it, add itbs, bump the compression to around 11s, more aggresive cams, injectors etc etc
unless you have money to burn then TT is the way to go for you :)
any ideas on a TT engine cost guys?
The going rate for an all in conversion, including installtion is around £2300 if it's starting with a 5spd. You'll also need to buy an uprated clutch.
NOS is the only option for big (ish) power on the NA, but it's very limited in it's use and at £60 a refill for a couple of minutes use is very expensive.
