Amir khan Posted October 4, 2009 Share Posted October 4, 2009 Hi guys, Been of the forum for a while with work. But need some help with a few small things to get my car back on the road. So you'l probably see a few posts started by me This one is about the upper suspension arm, according to a mechanic who i was getting to change my hubs and bearings, the upper suspension arm needs changing because the ball joint is worn. My question are, after doing some research are: 1. I can find replacement bushes which should be enough to solve the problem (right?), but i cant find anywhere to purchase the ball joints from. can anyone help? 2. What can i do to physically check the bushes and ball joint as I have never had to replace them im unsure as what they should look like. 3.Is it worth me changing all the rear bushes with a kit from whiftbitz while the rear is getting worked on? 4. while this is getting done how much extra should I look to getting the hubs and bearing changed, as I assume they cant be that hard when everything is out. Thanks in advance! Link to comment Share on other sites More sharing options...
Homer Posted October 4, 2009 Share Posted October 4, 2009 The ball joints are not available seperately, you need to replace the whole arm. They are quite expensive. You can of course replace other suspension components at the same time, but have a look at the cost before thinking too far about it, the parts are all expensive. Have a look on the Whifbitz website for the prices of genuine Toyota replacements, they tend to be a fair saving over going direct to Toyota. Link to comment Share on other sites More sharing options...
pistonbroke Posted October 4, 2009 Share Posted October 4, 2009 1. The ball joints are part of the arm, so can't be sourced seperately. Speak to Steve Manley or one of the traders on here for best prices (they're not cheap though). 2. Bushes vary in size and shape. Worn bushes tend to be cracked and go hard over years of abuse. Ask whoever is doing the work to have a gander at the bushes and get their thoughts on them. 3. Yes, though people like JamieP have had replacement bush sets fitted and not been happy with them and the feel of the car, IIRC Jamie said the stock bushes feel better than aftermarket ones. 4. Again, speak to the mechanic doing the work, they will certainly be easier to do if components relating to them are being removed as part of an existing job. Good luck mate. Edit, beaten to it Link to comment Share on other sites More sharing options...
Nic Posted October 4, 2009 Share Posted October 4, 2009 (edited) Front or rear upper arm? The bushes are an integral part of the arm so you'll need to buy a complete arm. I'd personally replace with OEM parts, as the stock suspension arms use spherical bearings rather than simple bushes. Ideally I'd replace the lot as the rest of the suspension is probably similarly tired, not a cheap job, but it will completely transform the handling and grip. See this thread http://mkivsupra.net/vbb/showthread.php?t=119349 Workshop manual here should help: http://www.turbosupras.com/pdfs/JZA80%20TSRM/SA.pdf http://img203.imageshack.us/img203/6692/frontsuspensionepc.jpg http://img97.imageshack.us/img97/6779/rearsuspensionepc.jpg Edited October 4, 2009 by Nic (see edit history) Link to comment Share on other sites More sharing options...
Kirk Posted October 4, 2009 Share Posted October 4, 2009 when you install new add a bit of copperslick inside the sleave in the bushes to prevent rust build up and seizing Link to comment Share on other sites More sharing options...
Amir khan Posted October 4, 2009 Author Share Posted October 4, 2009 Thanks for the help people. So it looks like il have to source two new upper suspension arms, probably for around the 100 mark if im lucky. As I cant get a new ball joint. As for getting the car to feel fresh again, what are the main parts I should look to replacing? lower suspension arms? tie rods? As for the bush kits, they are useful to replace the old bushes on an arm with a good ball joint is that correct? So should I look towards getting used parts of a supra in good nic, or replacing the bushes with a new kit, anyone have any experience in this? again thanks for the help! Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted October 4, 2009 Share Posted October 4, 2009 I had to replace an arm on my front suspension only month or so back. Although i think it was a lower one and it was £250 Link to comment Share on other sites More sharing options...
barneybrendan Posted October 5, 2009 Share Posted October 5, 2009 i might be able to get the ball joints replaced on the arms,will know by the end of the week.the arms are stupidly expensive.once i know will be putting up a post all helps to keep those running costs down a bit. Link to comment Share on other sites More sharing options...
pistonbroke Posted October 5, 2009 Share Posted October 5, 2009 i might be able to get the ball joints replaced on the arms,will know by the end of the week.the arms are stupidly expensive.once i know will be putting up a post all helps to keep those running costs down a bit. Good luck with it mate. Are you going to be putting the arms on your car afterwards to road test them? Link to comment Share on other sites More sharing options...
barneybrendan Posted October 5, 2009 Share Posted October 5, 2009 Good luck with it mate. Are you going to be putting the arms on your car afterwards to road test them? yes my ball joints arent too clever at the moment. Link to comment Share on other sites More sharing options...
pistonbroke Posted October 5, 2009 Share Posted October 5, 2009 yes my ball joints arent too clever at the moment. Nice one. If you manage to make this work, I'd imagine you'll be able to get whoevers doing it, a fair bit of work from people on here. Link to comment Share on other sites More sharing options...
