supradibbs Posted September 30, 2009 Share Posted September 30, 2009 I have the HDMI and the optical cable it worked on my Samsundg TV at home just trying it on my Dads who has the same TV and i get no sound What am i doing wrong Link to comment Share on other sites More sharing options...
Matt H Posted September 30, 2009 Share Posted September 30, 2009 Take the mute off! Link to comment Share on other sites More sharing options...
SupraShaun Posted September 30, 2009 Share Posted September 30, 2009 You may have to reset it/ reconfigure it, hold down the power button when you turn it on (3 or 4 seconds) until it beeps again. Link to comment Share on other sites More sharing options...
Sandy-m2 Posted September 30, 2009 Share Posted September 30, 2009 sellect the hdmi as the sound input? Link to comment Share on other sites More sharing options...
Ric Posted September 30, 2009 Share Posted September 30, 2009 sellect the hdmi as the sound input? Why if hes using optical? Link to comment Share on other sites More sharing options...
Bobbeh Posted October 1, 2009 Share Posted October 1, 2009 Sounds like the TV is expecting sound from the HDMI input but not getting it, as its being sent via the optical.. must be some settings on the TV to configure the audio. Link to comment Share on other sites More sharing options...
a98pmalcolm Posted October 1, 2009 Share Posted October 1, 2009 if your using the optical, go into you PS3 setting in the main menu. and make sure u have the optical out put set as the audio out, also in the TV settings check the sound imput settings (if there is one) Link to comment Share on other sites More sharing options...
dani_r Posted October 1, 2009 Share Posted October 1, 2009 if your using the optical, go into you PS3 setting in the main menu. and make sure u have the optical out put set as the audio out, also in the TV settings check the sound imput settings (if there is one) That's the one Link to comment Share on other sites More sharing options...
Scott Posted October 1, 2009 Share Posted October 1, 2009 Kick it harder! I too think the above might work. I'm thinking that maybe the settings have re-set when you plugged it into your Dad's telly? Did you turn it off in your house without changing anything then turn it back on in your Dads with everything exactly the same? I've noticed that if you plug things in different then turn it on, then sort it, it doesn't work right. Other than that i would say TV settings. Link to comment Share on other sites More sharing options...
