IS200 + 2JZ-GTE + single turbo
Chris Wilson
Guest Terry S
Chris that is Ray Hall's personal car, it's been floating around for about 3 years+. Reg Riemer has a gorgeuos VVTi example too which he uses in the US One Lap challenge.
...do you think hes snuck a cone filter on the end of that enclosed in the box? ...
Yeah, using a filter element with 3-4 times less the active surface is a good way to gain power, well if you believe the advertisers that's how it is, lol....
He's in a bad mood because internet access is extremely slow and very sporadic at work :D
Pod filters are great if you've got heatshielding and a bit of ducting :) And a good reason to have them. And they aren't green mushroom ones.
Must sort out my heatshield lol And some ducting. Still, one out of three isn't bad :eek:
-Ian
Ian, before ditching the HKS filter thing, I took the time to measure it's effective surface area: 1050cm2
Do you know how much the surface of the stock filter is? 5000cm2 mate.
Almost FIVE times as much.
Not even similar ball park figure, we're talking about a serious downgrade here...
Heat soak comes for free.
But hey, it sounds kewl, so that's good enough to spend money on it, it's a free market after all, each to their own.
