1722 RWHP 1115ftlb on a pair of 6765's
JamieP
  • Replies 56
Ahh i see:d mega money.
I dont see why.
(apart from engine life being VERY LOW)
Manifold?
2x bosch pumps £200
Decent fuel lines £100?
1600cc injectors ?
New clutch £2k
Maybe throttle body £1k
NOS £1k
Mapping £500
Our Intercoolers and other cooling should be fine.
Cant see where the extra is apart from Engine build which comes to about £10 without it being a strocker.
I assume every other factor is just limiting.
Anything i have missed?
I dont see why.
Manifold?
2x bosch pumps £200
1600cc injectors ?
New clutch £2k
NOS £1k
Mapping £500
What about the 15k building the 3.4 lump that he has and the 3 grand ish on a pair of turbos?
Oh and i missed another wastegate @ 500.
I wouldnt plan on running a stroker kit due to price.
Manifold 1k
turbo's 3k
another wastegate 500
Injectors 1k
Clutch 2k
The rest is there for a medium setup.
800's i presume its the stock lines holding me back? im just going to buy a full fuel system this time, i cant be arsed to make up lines like last time.
If the dyno print out i have seen is anything to go by you may be pushing it with race fuel dude, go for -8 or 6 and 2 pumps
Yup, ill more than likely go with the PHR stage 3:)
Our fuel system upgrades are pre-assembled in the box, and are ready to install without any special tools required. The PHR Stage 3 Fuel System includes the PHR 17.5mm (-10AN) ID high-flow fuel rail, twin Walbro GSS341 in-tank fuel pumps, Aeromotive EFI fuel pressure regulator, liquid-filled fuel pressure gauge, fully assembled and pressure tested -6AN Stainless Steel braided fuel lines, hi-flow fuel filter, Siemens 1000cc fuel injectors, PHR quick release injector clips, and all hardware necessary for a complete install. We even include a sheet of a space-age polymer used to wrap the fuel pumps to prevent magnetic interference. This is the perfect fuel system upgrade for customers needing to support between 850 and 1000 horsepower. A complete and high quality fuel system upgrade from the most trusted name in Toyota and Lexus performance.
Same for mine - still got my MR2 project to finish for JAE - then I'll think about what I'm doing with the Supra ...
I did hear a rumor about the possibility of a rather special engine going in your supra, is that off now?:)
Nope, I do have it sat in my garage - but I'm not sure about committing that much money too it. Maybe when I've paid the mortgage off ;)
