Homer Posted June 14, 2009 Share Posted June 14, 2009 Although I'm sure this advert is total rubbish! over 500 has been done Although John's was/is a UK! http://www.mkivsupra.net/vbb/showpost.php?p=768486&postcount=32 Hub dyno It'd been tried again, again and again, even hybrid's with an extreme spec list will only just deliver 450bhp. Link to comment Share on other sites More sharing options...
imi Posted June 15, 2009 Share Posted June 15, 2009 Naa if you go fully BPU it should see you nicely to around 420, anymore though and your probably going to need hybrids. on a UK perhaps, on a jspec....I would be a bit surprised. Link to comment Share on other sites More sharing options...
Matt H Posted June 15, 2009 Share Posted June 15, 2009 The max you're going to get from a twin turbo set up / hybrid or not is 450 approx. To even consider that kind of power from stock twins you need to up boost way over what they are capable off. boom. Link to comment Share on other sites More sharing options...
magictorch Posted June 15, 2009 Share Posted June 15, 2009 431 on a Jspec here;) Link to comment Share on other sites More sharing options...
Holden1989 Posted June 15, 2009 Share Posted June 15, 2009 431 on a Jspec here;) What mods have you done to gain this and where was it dyno'd? Ours on Hybrids is only pushing 400, new injectors and ecu should see it at 440, so very interested to see what you have done to yours Link to comment Share on other sites More sharing options...
magictorch Posted June 15, 2009 Share Posted June 15, 2009 (edited) What mods have you done to gain this and where was it dyno'd? Ours on Hybrids is only pushing 400, new injectors and ecu should see it at 440, so very interested to see what you have done to yours Spec in my garage:) But basically i have a Phr fuel kit (850 injectors) and a Solaris Ecu. Dyno'd at Surrey RR Axle's car is running a similar figure and Cheekymonkey's... I plan to see if i can get a bit more from mine as well Edited June 15, 2009 by magictorch (see edit history) Link to comment Share on other sites More sharing options...
magictorch Posted June 15, 2009 Share Posted June 15, 2009 Forgot its in TTC running 1.25 boost as well Link to comment Share on other sites More sharing options...
imi Posted June 15, 2009 Share Posted June 15, 2009 431 on a Jspec here;) so that sorts out the max power figure at the fly. would be interesting to see the dyno graph and the power curve. sounds like a good setup. Link to comment Share on other sites More sharing options...
magictorch Posted June 15, 2009 Share Posted June 15, 2009 so that sorts out the max power figure at the fly. would be interesting to see the dyno graph and the power curve. sounds like a good setup. Before and after in my garage Link to comment Share on other sites More sharing options...
pistonbroke Posted June 15, 2009 Share Posted June 15, 2009 The thing is, put the same car and two different dynos on the same day and you'll probably get two different figures. Dyno figures and printouts are one thing, getting in the car and being blown away by a well tuned setup is another. Link to comment Share on other sites More sharing options...
AlanM Posted June 15, 2009 Share Posted June 15, 2009 and it has been chipped - that is not possible either Link to comment Share on other sites More sharing options...
dude Posted June 15, 2009 Share Posted June 15, 2009 Although I'm sure this advert is total rubbish! over 500 has been done Although John's was/is a UK! http://www.mkivsupra.net/vbb/showpost.php?p=768486&postcount=32 Ahh the amazing hub dyno versus chassis dyno again, CJ's car made about 150hp more on thors dyno than it did on a chassis dyno, either way it depends on the operator, figures are easy to fudge if thats what you want to do. At the end of the day the proof of the pudding is in the eating. Look at what happened at TOTB when i had to race a 1200 hp car in the semis, mind you that was 1200 hp on thors hub dyno, maybe we are talling different horses:blink: Where the bullshit stops is when you put them on a strip or top speed run. Link to comment Share on other sites More sharing options...
dude Posted June 15, 2009 Share Posted June 15, 2009 On the dyno graph with 337 hp what was the setup??? Link to comment Share on other sites More sharing options...
magictorch Posted June 15, 2009 Share Posted June 15, 2009 On the dyno graph with 337 hp what was the setup??? 3' decats and a Apexi GT exhaust, Walbro pump, knackered Smic:d Running stock boost... Link to comment Share on other sites More sharing options...
imi Posted June 15, 2009 Share Posted June 15, 2009 The thing is, put the same car and two different dynos on the same day and you'll probably get two different figures. Dyno figures and printouts are one thing, getting in the car and being blown away by a well tuned setup is another. True, however in Magictorch's case, he dyno'd his car at SRR - same place as me and same place as quite a few cars on WEZ's ECU register....so worth looking into in my opinion. Link to comment Share on other sites More sharing options...
rob wild Posted June 15, 2009 Share Posted June 15, 2009 Hub dyno It'd been tried again, again and again, even hybrid's with an extreme spec list will only just deliver 450bhp. Ahh the amazing hub dyno versus chassis dyno again, CJ's car made about 150hp more on thors dyno than it did on a chassis dyno, either way it depends on the operator, figures are easy to fudge if thats what you want to do. At the end of the day the proof of the pudding is in the eating. Look at what happened at TOTB when i had to race a 1200 hp car in the semis, mind you that was 1200 hp on thors hub dyno, maybe we are talling different horses:blink: Where the bull$#@! stops is when you put them on a strip or top speed run. TBH I'm not really bother either way I was really only pointing out that John had achieve an impressive figure but as you say (quite rightly) dyno accuracy is major factor and figures can be manipulated. Just always found John to be very knowledgeable and not one to 'bs' for the sake of it. Speaking of TOTB dude im going to have get some tips off you matey and get some MT's Link to comment Share on other sites More sharing options...
dude Posted June 16, 2009 Share Posted June 16, 2009 Speaking of TOTB dude im going to have get some tips off you matey and get some MT's No problem dude, anything I can do to help give us a shout, are we allowed to use the MT's then??? Link to comment Share on other sites More sharing options...
