Dodge Challenger
MONKEYmark
just started to talking to an american car owner who does the drag strips, a couple own a smart looking american car. he does all his own work. his wife is into it and supports his passion too. below is email with specs of there car.
pretty impressive looking car. 10.13 @ 134.58 MPH
Below pics from AVON Park
http://www.surepixuk.plus.com/cars/root/et_classes/pro_et/dave_napier/ap0406_c4405.jpg
http://www.surepixuk.plus.com/cars/root/et_classes/pro_et/dave_napier/ap0408_c5798.jpg
There is a good album of pics on Feel-the-Noise - link:
Race Cars - ET Classes - Pro ET - Dave Napier (please ignore the funny face Tig's pulling on one photo!)
Also if you type Tig Napier in google, it should find pics from Eurodragster and various other sites.
we have a Torqueflite 727 reverse pattern manual valve body with a B&M shifter. All that means is there's no clutch but you still have to change gear using the shifter, and the reverse pattern bit means the gears are the other way round to a normal auto box, so you pull the shifter back to change up instead of pushing it forward. You are right about the approx. 700bhp ATW, Dodge specs are as follows (well, you DID ask) :-)
Tigs Challenger Specs @ 27/2/2005
Car ‘74 Dodge Challenger
Weight 3916 LB with driver
Full interior, (bar back seat) Kirkey aluminium seats
5-point harness.
Wilwood 4 pot caliper front discs
10 point roll bar. Drive shaft loop. Fire extinguisher. 2 Trunk mounted batteries.
Chassis ties, 6-pak hood (6 inch).
Be-Cool 2-row aluminium radiator
Moroso Electric water pump (no thermostat)
ENGINE
’99 M/P Mega 4 bolt block 4.5 bore
’99 M/P 4.15 stroker crank
ATi super damper
Ross Racing Pistons lightweight forged. Ross rings.
Manley sportsman steel rods, ARP bolts
Clevite bearings, ARP studs throughout.
Comp cams roller cam .737 lift with Comp cams roller lifters and smith bros. push rods
Cloyes true roller hex adjust timing chain
Milodon external oiling single line
Milodon sump
Balanced & Lightened
HEADS
Indy 572 - 13.
2.3 in, 1.88 ex, 81cc chambers (closed)
Jesel 1.6 ratio roller rockers (gives total lift of .737 in)
Spray bar oiling
Not ported
IGNITION SYSTEM
MSD 6AL Ignition module (7200rpm soft cut rev. limiter)
MSD Billet Distributor
MSD 8.5mm plug leads
GOING IN
Holley Dominator 160 GPH fuel pump
-12 fuel lines
Holley 1050 cfm Dominator carb
Indy 440 –3 single plane dominator pattern extensively modified
K&N 5 x 14 filter and max flow top
GOING OUT
Hooker Super Comp weld-up kit 2 1/4" headers 4" collectors.
Dual 3" exhausts
3" Flowmaster mufflers and Supertrapps
GEARBOX
’69 727 Auto
ATi 8 inch converter (custom)
B&M flex plate (8 bolt)
B&M Pro ratchet shifter
M/P deep sump
Griner reverse pattern manual, rear band apply valve body.
Billet steel front drum 6 clutch.
Race plates & kolene steels
4 pinion planetary gears front and rear.
Bolt in sprag
Oiling mods.
4.2 arm.
Solid servos
Trans cooler (run with – 6 lines in series with stock cooler)
REAR
Dana 60
4 spider LSD
Richmond 4:10 ring and pinion
SUSPENSION
Rear: - Caltracs, rancho shocks, Landrum monoleaf springs & pinion snubber
Front: - Stock, Small Block torsion bars, Competition Engineering adj. shocks (set at 90 / 10)
WHEELS & TYRES
Front Centreline Convo Pros 4½ x 15 M/T 26 x 4½ x 15 8-ply tyres
Rear Centreline Convo Pros 8½ x 15 5" back spacing 275 x 60 x 15 tyres
Race rear Centreline Convo Pros 8½ x 15 with 29.5" x 10.5" Mickey Thompson slicks (Biggest I can get underneath)
RESULTS
¼ mile times:
Best E.T. of 10.13 @ 134.58MPH
Best MPH of 135.68 on a 10.19 E.T.
Best 60’ of 1.503
Best 1/8 mile of 6.49 @ 107.63MPH (All from Avon Park)
Over winter Tig found a couple of things not quite as they should be, so we're hoping to go a bit quicker this year. And we've ordered a Keith Black aluminium block from the States to build a 572ci motor, that's to go in next year. We looked into a Turbo set up but it would cost far too much as we'd have to upgrade the chassis as well as getting all the engine bits and new engine. Don't think we weren't tempted though, twin turbos on similar Chrysler blocks in the States are producing over 2400hp!
Hope you haven't nodded off yet http://cdn-cf.aol.com/se/smi/0201d20638/01
Cheers,
Cath & Tig
Don't get me started on this one again ;)
It takes me back to the time when a lot of us were running similar cars, albeit not so modded, as daily drivers. Those were definitely the days :D
Problem being, with them all being 30+ years old, its not really practical these days, hence the Supra :)
3916 pound with driver and it still launches with front wheels off the ground with 700hp. i love the sound of the big v8 cars. its got a huge spec list, dont mention what ICE system he has in the car. was reading about v8 engines last night.
still a cool car even if it is old school.
I followed one of those from the M62 to York Dragway last season, I was in a 1.8 Vectra and all over him, then we got to one of those really long straights :)
(Caught him on the twisty bits though)
Cracking machines, great to watch those huge tyres flex as they dig in before the wheels lift.
