Which oil in a 6spd box
dude
Keeps Toyota in business.... :stickpoke
Good Question...not sure whether all this about NOT using V160 Oil is heresay or fact.
I have however heard it from several sources so ended up dishing out £60 for 2 Ltrs :violin:
I think there has been at least three people who chopped out their "just ATF" oil for the pukka V160 oil and had instanto results - easier shifting when cold and less clunking and no grinding. One guy I think couldn't even get into 2nd until it had warmed up and then it went in fine once V160 was in.
It lasts for aeons doesn't it? And it's the lifeblood of your beefy Getrag... I'd personally use the V160 stuff, same as I use Toyota ForLife and Valvoline Synpower and Optimax and Pirelli and Motul.....
-Ian
The toyota V160 oil is just Esso Dextron II ATF fluid repackaged in Japan and then imported. The Toyota manual specifies two oils: the V160 and Esso Dextron II ATF. A number of people have used other fluid including Royal Purple and Mobil1 ATF. To my knowledge the only fluid known to cause problems in the Supra V160 6-speed is Red Line MTB which due to excessive seal swell agent caused the bushing in the gear selector to stick and not recenter automatically.
I think I asked Oilman about this a while back on the forum. Even told him that the same gearbox was used in the Lotus Carlton, Porsche 968 and I believe the skyline R34 uses the getrag V160 as well.
It would be interesting to find out the oils that these other manufacturers reccommend and how much they charge for it. :)
One thing I recall being told was that there are additives in the V160 oil over normal Dexron II, and that seals and synchros can and have failed with non-V160 fluid.
Frankly, at just £50 every 36,000 miles, I'd rather not take a chance.
Its very strange that ive just ordered some from Toyota and there is none in the country :cry: :cry: !!! I wonder what they use if dont have any :p , Im going to get it analised and ill bet that there is no difference to ATF oil at all
Dude :sly:
I'll stick some in the post dude in a small bottle , the 160 oil looks , feels and smells the same as ATF and you know what they say , if it looks like a duck , sounds like a duck and feels like a duck , its prob a duck !!!! :thumbs:
Dude :cool:
