Guest jasoneverettbro Posted September 8, 2008 Share Posted September 8, 2008 Hi Everyone, Wonder if someone can shed some light on this. Last week my air con and heating stoped working, no lights, blower, nothing... I have checked the main fuse under the drivers side which is fine and had a look at the larger fuse unit under the hood. This is a sealed unit so not sure there... The clock has also died and this happened at the same time which leads me to think it is electrical.... any thoughts would be greatly appriciated. Thanks Supra peeps! Jase Link to comment Share on other sites More sharing options...
Guest Budz86 Posted September 8, 2008 Share Posted September 8, 2008 Maybe the altenator belt mate, but I'm not that technically minded. I think thats the belt that drives all the acessories. Does the car still start ok? Might also be something to do with the battery Link to comment Share on other sites More sharing options...
Guest jasoneverettbro Posted September 8, 2008 Share Posted September 8, 2008 Thanks mate, She still works perfectly, starting and roaring! it is literally just the heater/air con and clock. Jase Link to comment Share on other sites More sharing options...
Guest Budz86 Posted September 8, 2008 Share Posted September 8, 2008 Maybe a short somewhere or like you said, a fuse. Try pulling them all out and replacing them, should enable you to see if one is blown. On my punto, the same fuse 'controlled?' all of these systems Link to comment Share on other sites More sharing options...
Guest jasoneverettbro Posted September 8, 2008 Share Posted September 8, 2008 Thanks mate, will give it a go Link to comment Share on other sites More sharing options...
Dave17 Posted September 8, 2008 Share Posted September 8, 2008 I had similar to this when i installed my stereo, heating and aircon both dead, and all the lighting in that area as well, i just pulled all the fuses until i found the one that was dead. Link to comment Share on other sites More sharing options...
adnanshah247 Posted September 8, 2008 Share Posted September 8, 2008 have you put in any new ice in recently? you might have messed with some wiring..... Link to comment Share on other sites More sharing options...
RobSheffield Posted September 8, 2008 Share Posted September 8, 2008 Have you removed the dash recently? Link to comment Share on other sites More sharing options...
Guest jasoneverettbro Posted September 9, 2008 Share Posted September 9, 2008 Yeah, removed the dash a few times but the heating has worked between dash fits. I think I may have it now as the heating comes to life when you hold down the hour button on the clock.... Now all I need to do is fine that darn dodgy earth!... Thanks everyone for your help. Jase Link to comment Share on other sites More sharing options...
SteveR Posted September 9, 2008 Share Posted September 9, 2008 Probably isn't a dodgy earth as - I think - most of the controls back there have a +ve and a -ve feed. I'd check you plugged the connectors back in FIRMLY last time you had the dash out. Link to comment Share on other sites More sharing options...
TRD DAN Posted September 9, 2008 Share Posted September 9, 2008 i must check this asweel mines the same lol Link to comment Share on other sites More sharing options...
wile e coyote Posted September 9, 2008 Share Posted September 9, 2008 I had this The clutch on the AC compreser went which then caused a fuse to blow in the drivers footwell changed it but when i tried to put ac on again it just blew fine with ac off so needed new ac compresor Link to comment Share on other sites More sharing options...
supra steveo Posted September 9, 2008 Share Posted September 9, 2008 i had this the other week but it was just the OFF button was stuck Link to comment Share on other sites More sharing options...
marc_p Posted September 10, 2008 Share Posted September 10, 2008 Behind the dash there should be an orange box with 'ABS' on it, check that you plugged the wires back into it as it sounds like the wires for that have been left unplugged, it is usually located on top of the headunit. Link to comment Share on other sites More sharing options...
Guest jasoneverettbro Posted September 10, 2008 Share Posted September 10, 2008 Cheers, I will try all of the above. Here's to dash stripping at the weekend, I'll probably get it back together and find a new problem. Link to comment Share on other sites More sharing options...
