A fun game to pass the time on monday evening...
Guigsy
  • Replies 88
Completed them all.
Cant see your solution Aji as I'm at work but this is how I did it:
Build two small tanks linked together and a large wooden ramp.
The tanks climb the ramp and jump the gap. when the first losses tracktion the 2nd pushes from behind. Let both tanks run off the cliff and past the goal. I then built a very long rope with lots of links. in the middle I attached the trigger object and at the end I made an anchor. The other end I attached to the tanks.
When the tanks roll off the cliff they pull the rope and drag the trigger object over the hill and past the goal. when the anchor snags the ground with a bit of luck the trigger will swing into the goal zone.
