wilkorangerover Posted June 17, 2008 Share Posted June 17, 2008 my dash dimmer seems not to be working, but its was working only the other day??? any ideas?? Quote Link to comment Share on other sites More sharing options...
Jazzy Posted June 17, 2008 Share Posted June 17, 2008 Your using it without the lights on this time? Sorry Quote Link to comment Share on other sites More sharing options...
supra steveo Posted June 17, 2008 Share Posted June 17, 2008 Check fuses in dvr kick well i ordered a 2nd dimmer switch then realised it was a poxy fuse Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted June 17, 2008 Author Share Posted June 17, 2008 is it a fuse just for the dimmer or is it linked with a few other things? Quote Link to comment Share on other sites More sharing options...
Homer Posted June 17, 2008 Share Posted June 17, 2008 The dimmer switch is linked to most of the dash, if it's not working it'll effect many other instruments. Is anything else not working? Why do you question the dimmer switch in particular? Can you explain your problem in more detail? This is the last time I try to help you until you start writing proper posts with a full explaination. I guess you are new to computers/writing but it's very tiresome and frustrating trying to help you If you continue as you do then most people will simply not reply even though they have idea of the answer. If you want help, you must make the effort to explain your issue in full, otherwise you will get no replies. Quote Link to comment Share on other sites More sharing options...
Axle Posted June 18, 2008 Share Posted June 18, 2008 Homer has a point tbh. Quote Link to comment Share on other sites More sharing options...
DamanC Posted June 18, 2008 Share Posted June 18, 2008 Yup. Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted June 18, 2008 Author Share Posted June 18, 2008 is there any way of bypassing the dimmer switch??? Quote Link to comment Share on other sites More sharing options...
