10W-60 oil
AJI
 Share
  • Replies 64
I rechecked the OATS database this morning to see if there were any notes attached to the basic 10w-30 or 10w-40 recommendation and here's a C&P of what it says.
Engine oil viscosity recommendations (prior to model year 2000): 10W-30, 10w-40, 10W-50, 15W-40, 15w-50, 20W-40, 20W-50.
20w is better for warmer climates than the UK.
The important thing is sae 30,40 and 50 are recommended, not sae 60.
This info is from OEM.
Cheers
Simon
I very much appreciate the insight oilman has given us into why some oils are better than others even though they look the same on the tin.
ISTR Silkolene oils are very highly thought of in the motorcycle world where levels of tune regularly exceed that achieved in the car world.
PS. It's simpler in the Porker world, they simply approve the oils you should use by name and/or detailed spec and you can't really complain if you use something else and it goes bang. :thumbs:
As asked above how does the requirement change on an older vehicle (say 90,000 miles) with higher boost and other supporting mods to give 400bhp+ that is used on trackdays on a regular basis rather than posing around the streets?
A standard car given 'normal' use would use "x" - would the 'abused' vehicle still be OK with this or would you recommend a different formulation? I'm guessing that the stuff recommended for normal use has a slight overkill factor which would cover the extended thrashings but if you could offer your comments on this I'd be grateful.
If the older vehicle is in good nick then no need to change the recommended viscosity.
Mods are a different thing and generally it depends on the engine temps that you are running. Synthetic oils that contain pao/ester have much better thermal stability than petroleum oils so you can still use lower viscosities like 5w-40 or 10w-40 keeping the oil within the manufacturers specs without suffering from the oil thinning within a couple of thousand miles. This is why the oil also lasts longer.
This is a real email that I have permission to publish but names witheld and it illustrates the point I'm making about low viscosity synthetics in stressed applications.
Basically the quality of the oil is the key here and it's fair to say you get what you pay for always as decent oils cost more money to make.
Sent: 07 May 2004 16:16
To: Rowland, John
Subject: Peugeot Cosworth - result!
John
Just a note to let you know I've heard from xxx - the rally driver with
the 300+bhp Peugeot-ice-racer-bodied hybrid with the normally asthmatic
Cosworth in the back.
Prior to you taking over, he used to have to strip the engine after every event
(normally 45 miles, he couldn't get it to last for a National event of 70-80
miles) and change the big end bearings every time. He'd been everywhere and
tried everything (including Halfords!), and couldn't solve his problem.
First off, he was really surprised when you asked to look at the bearings, as
no-one had ever asked! He was equally surprised by your recommendation to go
thinner, and also, I have to say, worried. He equated 'thickness' with 'better
protection'. I eventually persuaded him to try Pro S 5w/40, as you suggested.
He called me to say he'd stripped the engine this week, after it's FOURTH event
(approx 200 competitive miles!), and there isn't a mark on it. He is utterly
delighted, and asked me to pass on his thanks for all your help and expertise.
I'd also like to add my thanks to you. He is extremely influential in
competition circles, and is now going to tell the world and his wife what, and
who, sorted this problem.
Once again, many thanks
Regards
Hope this helps, any more advice needed, just ask.
Cheers
Simon
Indeed I have a list and we stock many Porsche Approved oils.
We also have a deal with the mighty Porsche Owners Club GB.
Cheers
Simon
I'm not a member of the club they are a bit up themselves for my liking
:eek:
You'll no doubt be surprised to hear my 996 NA is swimming in Mobil 1 0-40 at the moment - what is the non-member's price please? Not sure how much I have left in the garage at the moment.
:eek:
Mail me at [email protected] and I will forward a price list on to you.
Cheers
Simon.
  • 13 years later...
 Share
