Aftermarket ECU for N/A
Guest Tom80
Does anyone have an aftermarket ECU installed on a J-spec N/A non VVT-i??
I've got a 95 5-speed and thinking of installing one, but I can't get enough info about it. Which one would be suitable (street use) ??
All the ecu makers will do a suitable six cylinder ecu. I use and recommend Motec, DTA and MBE units. Each of these makers list a suitable unit. Choose the make solely on who you have available to map it. For your application the mappers familiarity with a given ecu is more important than the ecu itself. ther's no point in another ecu unless you are changing cams and valves and upping the compression and getting rid of the AFM, in my opinion. Tuning an N/A is a LOT more expensive than medium power gains on a turbo unit. See below, written by me for a Vauxhall engined customer, but stll very applicable to your own engine:
Whilst not wanting to put a damper on your aspirations towards
better performance,the following general stuff in regard to tuning
late,fuel injected,electronically managed engines may help.
Post the early eighties,more and more manufacturers went to electronic
management of ignition and fuel,via fuel injection,and mapped ignition
systems. Most fuel injection systems had one immediate impact. They no
longer need a restrictive venturi (narrow throat) in the carburettor
(s) to pull fuel out of the fuel bowl of the carb. Fuel injection
*injected* the fuel under high or very high pressure. No restriction as
such,and hence less of a power loss. Management of the ignition and
fuel suddenly meant engines could get away with running camshafts with
greater overlap,and higher lift,too. The old advance weight disi,and
velocity sensitive carb limited what cam profile could remain
driveable, without hesitations,poor low end performance and flat
spots. To a large extent electronic management allowed much more
freedom in valve sizes,port shapes,and cam timing,as well as running
the engine at the best amount of ignition advance at all loads and
RPM's without detonation,on differing fuel qualities,via knock sensor
technology.
What I am slowly getting at is that it is *much* harder to get
anything like a useful power gain from a modern,well designed,16 valve
production engine on electronic management. The exhausts are free
flowing,as are the intake systems. One needs to look at further
performance optimisation of the cam profiles,and maybe bigger
valves,stronger valve springs,moves away from hydraulic valve lifters
and mechanical improvements to make higher revs safe,from a
mechanical stress related point of view. Almost any change that has the
potential for a marked improvement in power and torque,will require
different fuel curves (the amount of fuel injected at any one set of
parameters of air flow,temperature,engine RPM etcetera,etcetera),and
different timing curves. One can fudge the fuel,*across the whole
curve*,by increasing fuel pressure via an "up rated" fuel pressure
regulator,but the the weeks of dyno testing to get the fuelling
correct at every point,has then gone to pot ... :-(
As for the ignition,there is very little indeed you can do to change
the curve incrementally. Unfortunately,the *correct* answer is an
aftermarket injection system,or at least an aftermarket ECU and
wiring,that allows one to map the curves afresh,to suit your new power
modifications. This is expensive,both in terms of hardware,(maybe over
£1000 for the ECU and wiring loom),plus a lot of professional engine
dyno time to get it all mapped correctly.
Sometimes one can buy a complete package,say new cams,different
throttle bodies and manifold,etcetera,that can come complete either
with a modified EPROM for the existing ECU,or an aftermarket mappable
ECU complete. If one limits mods to exactly those which the kit
manufacturer intended,this should work well. If you change any
parameter from the tuners package,the early comments about incorrect
curves again apply..
Changing the exhaust *system* or the air filter,on 90% of modern
engines will do sod all.The mags claim this and that,but in reality a
gain of 5 HP on a 120 HP engine is neither here nor there,for a road
car. Humidity variations can see that much change. A rolling road is
hard pressed to accurately repeat to 5 BHP on a figure of 120 HP
total. To get greater gains,say 20 HP,you need to look at fairly
dramatic alterations,both to the mechanical components,and their
related fuelling and ignition curves.
Turbo engines are a slightly different kettle of fish,as it is trivial
to raise the boost,and usually to fudge some additional fuelling.
Naturally aspirated remain tricky!
The easiest/cheapest way to see increased performance is to reduce
weight. Especially rotating weight,for improved acceleration. Do most
people ask the most important question when buying new wheels,after
ensuring the offset and sizing is correct? Do they *uggery :-) They
should take a fishermans scales with them,and weigh the damned
things. The first question a race car manufacturer asks his potential
wheel suppliers is what do they weigh,and what is their rotational
inertia. Simple questions,and the weight,if not rotational inertia,is
easily self assessed performance differences can be
surprising,and worthwhile. Given 3 different makes of tyre,with similar
grip and handling characteristics,go for the lightest..Just weigh some
of the cheap imported tyres against a decent performance make,like a
Hoosier competition tyre that is road legal. The difference is
amazing. As for remolds,they are incredibly heavy.
If you are serious,and can live without goodies,buy a car with the
minimum spec. Sun roofs,air con,PAS,electric windows and mirrors,power
seats all can add hundreds of pounds. Lightweight front seats can add
as much performance,in real terms,as a new exhaust and manifold. 40
pounds of fancy stereo gear does nothing for performance ;-)
As cars become better,and more highly developed,the art of tuning
their engines becomes more complex and expensive,unless one looks at
the situation with a bit of lateral thinking. Instead of adding
things,think in terms of removing them. Instead of buying a new set of
wheels just for their looks,weigh them,and see if a gain can be had
for free there.
Just ideas,some may be practical for your situation,some not,but be
aware it is all too easy to buy so called performance bits,and get the
thing to go *slower* At least the engine in your car starts off as
one of the best basis for tuning available.
To answer to Chris Wilson, that's actually more or less what I plan to do. Thanks for your wise opinion, I'll think about it when I'll set up my car. I like turbo Supras for their massive power, but I went N/A to make it a well-balanced handling machine to use it for both street and track use. I don't pursue high hp figures with that project, also I wanted to keep a certain flexibility proper to N/A engines. I've seen seriously tuned N/A Supras taking over tuned TT's on tracks (Tsukuba, Motegi,...), even though they were 100-150 hp less powerful. In that case, it's a matter of balance. I still like the Supra and its layout, and the N/A has its own potential, I believe. I wonder what can do a 700-750 rwhp TT on a road track like Tsukuba. Can they put all the power on the ground?? Don't misunderstand, guys, I like that too, but my aim this time is different...
One of my mates got a racing-tuned up N/A, putting out 250 rwhp on a dyno...for the price of a TT (which is about the same power here in Japan). He can still drives it everyday. That car is incredible on a track and is still very reliable.
Currently, the car is almost bone stock, I didn't do anything on it since I bought it a year ago: That's what the previous owner did:
TRD air filter element
Fujitsubo Legalis R muffler
Denso Iridium Power spark plugs
18" Aluminium wheels with Bridgestone Potenza GIII (235/40/18 F and 265/35/18 R) (Quite heavy, I guess, but I got the original 16" rims)
Odometer reads 49000 kms, it's still a good base to start.
Speed limited at 180 kph (mmmhh...), 1995 model, J-spec, 5spd MT, Torsen diff.
I'll start from a correct suspension/wheel alignment setup, then brakes, body reinforcement and weight reduction, and engine/clutch/diff tune-up. If you have any suggestions, let me know...
PS: I've seen a lot of posts in this forum of people ashamed of owning an N/A...High hp TT's can push really hard on freeways (and it's really exciting, I admit), but a correct N/A tuning will leave them far behind on a track for the same price. Your point is somewhere else. Fun is not a straight line...
