Results 1 to 11 of 11
Thread: Coolant leak, but where from?
  1. #1
    '96 BPU TT Club Member Mk4Gaz's Avatar
    Join Date
    Jul 2013
    Location
    England - Essex
    Posts
    2,811
    Feedback
    14 (100%)
    Hi guys, went out for a quick drive this morning, just a gentle plod. Anyway, when I got home, I noticed I had a small coolant leak under the car.
    I've had a look, and it appears to be coming from between the engine, and bulkhead. Its dripping on to the bell housing, and subsequently on to the floor.
    I can't tell exactly where it is, and haven't started stripping it down yet, but wondered if there were any common places to look for?
    Pretty sure its not the heater matrix pipes, as they are above the engine, this is definitely lower down. My guess is turbo coolant lines or throttle body coolant supply?
    The problem I'm faced with, is to strip bits back, the engine needs to be cool, and when its cool, there's no leaks!
  2. #2
    '93 SZ-R Aero NA-T Moderator Josh42's Avatar
    Join Date
    Jan 2011
    Location
    England - Staffordshire
    Posts
    3,925
    Feedback
    25 (100%)
    My guess is on the coolant hose right at the back by the bulkhead that goes into the block in the centre of the cam covers!
  3. #3
    Join Date
    Jul 2013
    Location
    England - Essex
    Posts
    2,811
    Feedback
    14 (100%)
    Thanks Josh, how difficult, what sort of job is that likely to be if it is that?
    Also, how best to attack it, what should I remove - turbo or inlet side?
  4. #4
    Join Date
    Jan 2011
    Location
    Posts
    3,925
    Feedback
    25 (100%)
    Neither mate. You can get to it by removing the plug cover and its just a jubilee/spring clip holding it on
  5. #5
    Me? Post? Never! Club Member supra_ufo's Avatar
    Join Date
    Sep 2012
    Location
    England - West Yorkshire
    Posts
    4,284
    Feedback
    14 (100%)
    http://www.mkivsupra.net/vbb/showthr...x-coolant-leak
    could be these as mine appeared to be coming from underneath
  6. #6
    Hardcore medallion man Club Member markssupra's Avatar
    Join Date
    Nov 2005
    Location
    England - Essex
    Posts
    2,938
    Feedback
    11 (100%)
    There is also a stainless steel coolant pipe that runs round the back of the engine to feed the oil cooler on the filter housing, cant see it being that though as there are no joins there.
    My HKS GT 2835 Big Twins AeroTop project
    "ere, do you reckon we could gatecrash that spit roast over there!"
    quote Lee S, JAE 2008
    Precision Industrial Cutting Tools for Metals, Metal Matrix Composites, Composite materials and Wood
    GZ TT Aerotop BPU. 313 RWHP. Engine Advantages 30/03/08, soon to be HKS Big twins
    GZ TT Aero R.I.P. 2004
    Chair cover hire for weddings or occasions
  7. #7
    Join Date
    Jul 2013
    Location
    England - Essex
    Posts
    2,811
    Feedback
    14 (100%)
    Thanks for the suggestions guys, at least it gives me a head start in tracing it
    Quote Originally Posted by supra_ufo View Post
    Pretty sure its not those dude, I remember reading your thread, and they were the first place I looked. I've felt around those pipes and they were bone dry.
    I definitely think its in the same area, but lower down.
    I could of course be wrong, its not unknown lol!
    I'll whip the cam cover off tomorrow if I get a chance, and see if I can get a better look. I want to replace the coil plugs anyway
    Now, just need to remember where I put the new coil plugs
  8. #8
    Join Date
    Sep 2012
    Location
    Posts
    4,284
    Feedback
    14 (100%)
    Quote Originally Posted by Mk4Gaz View Post
    I had to take the hoses off to find the leak though, it was seaping at the back of the cover and then tripping further down the car so at first it didnt look like it was coming from the engine bay. It was leaking by the fuel filter there are some brake lines around there.
  9. #9
    Join Date
    Jul 2013
    Location
    England - Essex
    Posts
    2,811
    Feedback
    14 (100%)
    Mine appears to be hitting the drivers side of the gearbox, almost dead centre of the engine, but running around the o/s
  10. #10
    Join Date
    Sep 2012
    Location
    Posts
    4,284
    Feedback
    14 (100%)
    Defo not same as mine then. Like someone said it sounds like the two hoses under the 2nd turbo...
  11. #11
    Join Date
    Jul 2013
    Location
    England - Essex
    Posts
    2,811
    Feedback
    14 (100%)
    Hmmm, sounds like its gonna be a sod to sort out , especially as it only appears to leak when the engine is hot
    Out with the spanners it is then!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
