Decatting an N/A
Daston
 Share
sweet any idea how much they are or how long it takes labour wise? Thinking of am xmas prezzy for the old girl
Contact member Chris Wilson, he supplies individual pipes to replace the first and second cats, the advantage of 2 separate pipes is that come MOT time the 2nd cat can be replaced easily.
Oops ment one CAT
My '95 NA passed fine with no cats on!
Bearing in mind all NA's are imports, the number plate and chassis/eng numbers will probably not show up on the new MOT system, so they HAVE to run the test ion the default setting - meaning higher pass levels and 99.9% chance of both cats off passing OK!
Hope yours goes fine, cats off is a simple job, undo bolts, replace gaskets, rebolt.
Simple
 Share
