garetheves Posted May 5, 2005 Share Posted May 5, 2005 Ok this could take a while to explain so please bear with me cos its got me a bit worried. A number of weeks ago the red warning triangle started to come on while driving. No apparent cause or regular pattern and it only stayed on for a few seconds and then went off. No problem. Had a chat with a few people on here and they thought it was more than likely the brake fluid level a little low. Anyway work has been really busy and havent got round to sorting it yet. Its gradually been coming on for longer and longer until day before yesterday was on for entire half hour journey (a bit worrying as im sure you can imagine). Now heres the weird bit and it may be completely unrelated and a complete coinsidence, but i think not. Drove round to Maccy D's last night and while parked in car park eating, the car idled very low, so low in fact i thought it was gonna cut out. Made the car actually shake. Did this on a and off for bout 10 mins until i set off and it very nearly stalled, despite high revs. Then for the enxt 30 mins of driving, very slowly i might add, it actually did cut out regularly and very briefly. it was as if the car had been turned off and back on again quickly. Made the car lurch forward as it decelerated a bit, then lurch again as it started again. After bout half hour or so it stopped and havent had a problem since, although have been taking it very easy. Basically im wondering 2 things: 1. WTF is up with it. 2. Are the triangle and the idling linked in some way. Any help would be much appreciated. Cheers in advance. Gaz P.S. sorry for the long post but i feel its easier with as full a description as possible. Quote Link to comment Share on other sites More sharing options...
GlennMR2 Posted May 5, 2005 Share Posted May 5, 2005 have you checked for any codes yet????? Quote Link to comment Share on other sites More sharing options...
garetheves Posted May 5, 2005 Author Share Posted May 5, 2005 unfortunately dont have the equipment here. would need to get it booked in at Toyota and would rather avoid there prices if possible. Quote Link to comment Share on other sites More sharing options...
Kopite Posted May 5, 2005 Share Posted May 5, 2005 you can check for fault codes using a staple mate, bridge TE1 and E1 on the diagnostics port. any other warning lights on anywhere? Quote Link to comment Share on other sites More sharing options...
garetheves Posted May 6, 2005 Author Share Posted May 6, 2005 No other warning lights, cars not over heating o anything like that. Quote Link to comment Share on other sites More sharing options...
garetheves Posted May 6, 2005 Author Share Posted May 6, 2005 whats a staple mate? Quote Link to comment Share on other sites More sharing options...
Pete Posted May 6, 2005 Share Posted May 6, 2005 Serviced recently? Plugs, fuel filters etc? Quote Link to comment Share on other sites More sharing options...
Steve Posted May 6, 2005 Share Posted May 6, 2005 Try a paper clip then! Quote Link to comment Share on other sites More sharing options...
garetheves Posted May 6, 2005 Author Share Posted May 6, 2005 It was serviced in December with full oil change and everything. Do supras have a warning light come on for when it needs a service, i know some cars do. Smarty: So what do i do with this paper clip then? Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 6, 2005 Share Posted May 6, 2005 Checking for error codes Is it UK spec or J spec? And how's the fuel economy? -Ian Quote Link to comment Share on other sites More sharing options...
Steve Posted May 6, 2005 Share Posted May 6, 2005 Thanks Ian. Was trying to find that link. Obviously didnt look very hard!! Quote Link to comment Share on other sites More sharing options...
Pete Posted May 6, 2005 Share Posted May 6, 2005 It may have sucked up some crap from the tank or something? Been to any dodgy filling stations? Was the fuel guage low when it happened? Worth checking fuel filters perhaps? Quote Link to comment Share on other sites More sharing options...
garetheves Posted May 6, 2005 Author Share Posted May 6, 2005 Its a J-Spec. Use the same fuel from the same station every time. The warning light has been there a while now, just staying on longer and longer. The missfiring seemed to start with about just over quater of a tank left. Happened again this morning when i took it out. Quote Link to comment Share on other sites More sharing options...
Steve Posted May 6, 2005 Share Posted May 6, 2005 Have you tried getting a code from the diagnostics port? Quote Link to comment Share on other sites More sharing options...
garetheves Posted May 6, 2005 Author Share Posted May 6, 2005 Am going away for the weekend but thats the first thing im gonna try on monday when im back, now that link has been posted. Quote Link to comment Share on other sites More sharing options...
Steve Posted May 6, 2005 Share Posted May 6, 2005 Hope you get it sorted! Quote Link to comment Share on other sites More sharing options...
garetheves Posted May 6, 2005 Author Share Posted May 6, 2005 Me too. its getting me quite worried cos in the middle of buying firrst house so if its somat serious i aint gonna be able to afford the repairs. Quote Link to comment Share on other sites More sharing options...
ardasaliah Posted May 6, 2005 Share Posted May 6, 2005 Hi, Don’t reset the ECU- this will clear the codes. Basically the car has logged the fault as the triangle has come on. Once you have done the error code test the fault will show up. Sounds like a faulty sensor somewhere. Possible MAP sensor or idle control valve. Let us know. Quote Link to comment Share on other sites More sharing options...
GlennMR2 Posted May 6, 2005 Share Posted May 6, 2005 gaz... go out and test for codes now, it will only take you 30 sec Quote Link to comment Share on other sites More sharing options...
garetheves Posted May 9, 2005 Author Share Posted May 9, 2005 Just been out to check error codes and bridged the wire with a paper clip, turned ignition to 2 but the warning light doesnt flash it just stays on permenantly? Am i doing somrthing wrong. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 9, 2005 Share Posted May 9, 2005 Yep, you are doing something wrong It's not a plastic coated paperclip is it har har But seriously, if you've done it right you'll either get a regular flash indicating no stored codes, or the code numbers will be flashed. A steady light means it's not in diagnostic mode. Incidentally, bridging those two pins puts the engine into limp-home mode as well so don't forget to remove it afterwards... -Ian Quote Link to comment Share on other sites More sharing options...
tbourner Posted May 9, 2005 Share Posted May 9, 2005 Is it the engine warning light that flashes and not the triangle? From your description it sounds exactly the same as what my car did after fitting my FCD badly, and having a dry joint on the 12V to the ECU under the passenger footwell, the FCD signal was gone completely so it didn't know where to idle or what revs I was at when pulling away! Quote Link to comment Share on other sites More sharing options...
garetheves Posted May 9, 2005 Author Share Posted May 9, 2005 Its defo not a plastic coated one. dont know what im diong wrong though. Im assuming you dont turn the engine on fully, just turn it to position 2 when all the warning lights come on. Also is 15W/40 oil ok for a decatted TT? Quote Link to comment Share on other sites More sharing options...
wez_p Posted May 9, 2005 Share Posted May 9, 2005 will it make it to Mascrat tonight? if so, maybe one of the other Supra owners will know how to do it properly? Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 9, 2005 Share Posted May 9, 2005 Its defo not a plastic coated one. dont know what im diong wrong though. Im assuming you dont turn the engine on fully, just turn it to position 2 when all the warning lights come on. Also is 15W/40 oil ok for a decatted TT? So you've got pins TE1 and E1 shorted in the diag port (you've not got a VVTi I assume:) ) and you turn the ignition to position 2 *and deimmobilise the car* and the light is just lit up? Hmmm. -Ian Quote Link to comment Share on other sites More sharing options...
