Chiefgroover Posted May 4, 2005 Share Posted May 4, 2005 If one were to purchase the HKS T04R kit, would one have everything they need? or is the fitting kit a little lame?. What would be optimum boost for road use, and what size of injector would one use?. What would be a competitive price to purchase at? Link to comment Share on other sites More sharing options...
dude Posted May 4, 2005 Share Posted May 4, 2005 Why particularly that kit dude , i may be wrong but i think you have to lift the head or block to fit it . Dude Link to comment Share on other sites More sharing options...
Jake Posted May 5, 2005 Share Posted May 5, 2005 Hi Chief, Isn't the T04R a bit of a slow-spooling dynosaur (DYNO-saur, ho-ho) these days? I think there are much better choices for a 'street-able' car. Or were you just planning on drag racing and dyno-queening it up? I didn't that was your cup of tea. (DISCLAIMER : The above is based on ZERO first hand knowledge, just what I've read) Link to comment Share on other sites More sharing options...
Chiefgroover Posted May 5, 2005 Author Share Posted May 5, 2005 As you know singles arn't my thing, but from internet reasearch T04r.com etc seems the manifold is the best and it pulls from pretty low. I am open minded on this one, so feel free to suggest. 650RWHP would be nice especially if I could get it to pull hard from about 3K ish. (pigs may fly i know lol) Car's other mods would be FMIC, double decat, dragger, F con pro, 264 cams, twin spark, and whatever injector i would need. Dyno sheets etc would be good to see with your recomendations. Link to comment Share on other sites More sharing options...
Chiefgroover Posted May 5, 2005 Author Share Posted May 5, 2005 Anyone tried titanium shafted turbos? Link to comment Share on other sites More sharing options...
Jake Posted May 5, 2005 Share Posted May 5, 2005 Anyone tried titanium shafted turbos? No, but I've tried a few shafted ones. Link to comment Share on other sites More sharing options...
Nic Posted May 5, 2005 Share Posted May 5, 2005 Chief if you go for HKS you should look at the new T04Z DBB turbo. Link to comment Share on other sites More sharing options...
Ian C Posted May 5, 2005 Share Posted May 5, 2005 You know people always say "Full boost by x rpm"... I find that daft because depending on what gear you are in, full boost comes in at different points. Last night my T67 got on song at 5000rpm But I was in first gear The other day I hit 1 bar of boost at 3300rpm But I was in 6th Maybe a graph of rpm-vs-boost-vs-time would be useful...? -Ian Link to comment Share on other sites More sharing options...
Alex Posted May 5, 2005 Share Posted May 5, 2005 As per Nick's comment the T04R has been replaced by the T04Z. It's a T67 sized turbo...so you'd see performance similar to Ian's ie in 6th 1bar at 3300rpm.... Link to comment Share on other sites More sharing options...
Guest Terry S Posted May 5, 2005 Share Posted May 5, 2005 HKS use some BIG exhaust housings. These are pretty much bog stock Garrett items rebadged ( not necessarily a bad thing). The T04R will make similar power to a 67 GTQ but with more lag. Link to comment Share on other sites More sharing options...
Chiefgroover Posted May 5, 2005 Author Share Posted May 5, 2005 I find that daft I wasn't referring to 1st and 2nd gear , not often i'd pull hard from low rpm on them so its not an issue. 3rd however I do care about, so I'd like to, if possible achieve a strong pull from the low 3's if any of the modern turbo's will spool that quick, and give 650ish rwhp at the same time. Maybe not but some of you guys ought to know. Link to comment Share on other sites More sharing options...
Guest Terry S Posted May 5, 2005 Share Posted May 5, 2005 I wasn't referring to 1st and 2nd gear , not often i'd pull hard from low rpm on them so its not an issue. 3rd however I do care about, so I'd like to, if possible achieve a strong pull from the low 3's if any of the modern turbo's will spool that quick, and give 650ish rwhp at the same time. Maybe not but some of you guys ought to know. I assume you dont mean 650rwhp on pump fuel! A genuine 650 rwbhp car would be undrivable at that level on the road. People seem to forget that. If you want a truly fast road car somewhere around a genuine 550 fwbhp is more realistic. Anyway, you aren't going to get 650 rwhp with fast spool I am afraid. Link to comment Share on other sites More sharing options...
Chiefgroover Posted May 5, 2005 Author Share Posted May 5, 2005 Anyway, you aren't going to get 650 rwhp with fast spool I am afraid. Thats answers the question 100%. Thanks Terry Link to comment Share on other sites More sharing options...
Guest Terry S Posted May 5, 2005 Share Posted May 5, 2005 No problem I still believe the bone stock BL kit with a T67 is probably the best street performace/£ compromise, whilst being able to make 650+ fwhp if pushed with proper fuel. The T61 will out spool this, and makes an awesome choice for a street racer. Link to comment Share on other sites More sharing options...
Ian C Posted May 5, 2005 Share Posted May 5, 2005 I wasn't referring to 1st and 2nd gear , not often i'd pull hard from low rpm on them so its not an issue. 3rd however I do care about, so I'd like to, if possible achieve a strong pull from the low 3's if any of the modern turbo's will spool that quick, and give 650ish rwhp at the same time. Maybe not but some of you guys ought to know. I wasn't accusing you of being daft, that may have been read wrong I've got some data from a 3rd gear run, hold on while I sort it out... -Ian Link to comment Share on other sites More sharing options...
Ian C Posted May 5, 2005 Share Posted May 5, 2005 OK here is a 3rd gear run. My driving style means I ease in the throttle over a period of about 1 second so the turbo is already boosting by the time I hit WOT, hence the graph starting at .3bar. Also note the boost controller probably needs sorting out a bit better as boost buildup really tails off at 1bar. The flat spots on the graph are an artefact of the E-Manage's datalogging, not some misfire problem However, all that aside, this shows you quite nicely what 3rd gear is like from -Ian Link to comment Share on other sites More sharing options...
Chiefgroover Posted May 5, 2005 Author Share Posted May 5, 2005 Pretty darn good, goes very nicely, thanks for that. Are there T67 options or all they all the same? Cast vs Tubular manifold what do you guys think? Whats the average cost of a T67 setup? Average Install time by an experienced mechanic? Link to comment Share on other sites More sharing options...
Guest Terry S Posted May 5, 2005 Share Posted May 5, 2005 There are options on the T67. The base kit is the P trim. Price wise, you are looking £2650 for a full tubular with HKS wastegate. Fitting, if you really steam in should be around the 2-3 full days. We sell Arnout's cast Manifolds ( in stock), but dont have a complete kit ready for it yet. HTH Link to comment Share on other sites More sharing options...
Alex Posted May 5, 2005 Share Posted May 5, 2005 P-Trim 67 spools faster but gives away 50RWHP to the GTQ which obviously spools slower. There is a DBB option which in GTQ form might well spool as fast as the P-trim standard one, but don't quote me on that. Cast or tubi doesn't really matter IMO. You're not looking for the last nth in performance like a race car. But I'd go for a Tubi if I could, just because. Arnout's cast manifold though is a very viable option. Ian's setup is a P-Trim with Tubi on a 3" exhaust. You can get a 4" option which might help the spool. Link to comment Share on other sites More sharing options...
Chiefgroover Posted May 5, 2005 Author Share Posted May 5, 2005 Thanks Alex, I am getting the picture slowly. The T04Z you mentioned, do you know anyone who has one fitted, I am just trying to get it right so I dont buy a kit, fit it and then start the old "if only i had gone for".............. DBB sounds good, but I am curious about any titanium internals, can only be good me thinks. All info post it here :-) Link to comment Share on other sites More sharing options...
Bobbeh Posted May 5, 2005 Share Posted May 5, 2005 Could always go for a T88 I dont know what all the lag fuss is about, when you're racing and in gear it'll shift.. just like this guy Save target as Link to comment Share on other sites More sharing options...
Markie Posted May 5, 2005 Share Posted May 5, 2005 So all this T61 T67 etc.. What are the size of the stock ones? Cheif, is the TO4Z a T67 or bigger? What about just putting bigger turbos on the existing SEQ setup? From reading this.. I think the best of both worlds so far is the T67 DBB GTQ? Link to comment Share on other sites More sharing options...
Chiefgroover Posted May 5, 2005 Author Share Posted May 5, 2005 Markie, I aint the one to ask on singles. These guys replying are that dept. Sequential........HKS did make an upgrade kit but lost interest. If you search the forums you'll see one of these kits installed. Apparantly only one in the UK somewhere that was done by Tdi. Rumour has it most kit buyers went for the big GT twins as the difference in money wasn't that big and the GT twins gave a load more power. Well thats my info on it, maybe someone knows better. Phone Tdi and speak to Nathan he will know if anyone does. Link to comment Share on other sites More sharing options...
Chiefgroover Posted May 5, 2005 Author Share Posted May 5, 2005 BOBBEH, nice one, thats a real tyre eater :-) Link to comment Share on other sites More sharing options...
TRD3000GT Posted May 6, 2005 Share Posted May 6, 2005 OK here is a 3rd gear run. My driving style means I ease in the throttle over a period of about 1 second so the turbo is already boosting by the time I hit WOT, hence the graph starting at .3bar. Also note the boost controller probably needs sorting out a bit better as boost buildup really tails off at 1bar. Ian , How come you are only letting her top out at 1 bar ? Im hoping to run mine at 1.3 - 1.4 ? Link to comment Share on other sites More sharing options...
