2JZ GTE VVTI Supra engine
T2 MSW
 Share
For sale 2JZ GTE VVTI engine with the below ancillaries ready to fit into a supra. Engine is ready for a single turbo kit and ready to drop into car. Everything has been checked and refreshed if required as below.
Stock bottom end with all bearings checked.
Completely striped, cleaned and refreshed head. All with stock new genuine Toyota parts. New valve guides and valve stem seals.
New genuine Toyota head gasket and all seals/gaskets throughout
ARP Head studs
New oil pump
New water pump
All new gates belts
New genuine toyota thermostat
Painted cam covers with -12an breather adapters
Cleaned and painted VVTI intake
£3000 collected, engine is currently on engine stand, have Crain if required.
Thread tidied up
Thank you
Is this complete.with loom ecu
Turbos ect
Its everything thats in the first post. As I said its ready for a single turbo install so no stock turbos on it and no wiring loom, Although saying that I can supply an aristo loom but thats no good to go into a supra.
  • 2 weeks later...
is there a difference between them besides a sump?
Minor. Below are the differences I know about
Sump
Wiring loom is shorter
Alternator plug is different
Air con condenser is completely different.
Block and VVTI head are exactly the same.
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
 Share
