Aircon delete - power steering pump support query
and1c
 Share
Firstly I'm posting this off mobile in case grammar etc is a tad messy.!
I'm putting the car back together after a major refurb session , engine out , Titan box , hi stall, new braided turbo oil drain and multiple other hoses and fittings and loads of other stuff.
Anyway my aircon pump seems to be a tad rough when spun at the pulley and I decided to remove it and put a brace on and shorter belt (but keep the parts in case I want to put a new pump back in the event I want aircon)
I can't for the life of me see where the ps pump is meant to be supported apart from using the brace kit I bought which has a spacer and strut, that clearly only secures one side. I don't want to have to refit the aircon pump at this stage.
If I pivot the ps pump to fix to the only nearby block bracket the pulley is too close to the tensioner. Anywhere else and the unchanged ps reservoir hose won't stretch.
Am I missing a bracket here???
Also does anyone know where I can get a new ac pump in case I need it or maybe a recon place ?
Thanks
I have seen several ruined engine blocks and many ruined PAS pumps where people have deleted the whole A/C pump and left the PAS pump hanging off one poor little boss cast into the engine block, and flexing about to the detriment of the pump's bearings and the drive belt..
HI Chris. Thanks for the input!
Funny you mention this as I am not overly happy with the solution bracket at all and have been looking at that lug on the block with some concern in the event that it broke.. Even with the PS bracket bolts it doesn't seem to offer anything like the same lateral support as the aircon pump bracket. On that note.... I will probably have to try and source a new aircon pump!!!!
update// I will see if I can replace the bearing on this one. As it works fine but seems a little rough. Anyone know what bearing it is?
Edited by and1c (see edit history)
I haven't time to go into depth, nor have I read the earlier link to an aricle on how to remove the A/C pump, but I would disassemble the pump and use the front of its casting as the support bracket.
The front bearing should allow the pulley to spin pretty freely by finger rotation, with minimal drag. The pulley should only attempt to drive the pump when 12 Volts is applied to energise the electromagnetic clutch.
Cheers. Been reading up on how they work, will strip it and see. Will probably end up keeping aircon at this rate!
- - - Updated - - -
pumps on the bench anyway Chris. Thanks for the heads up, wont be doing the AC delete anymore!!!
Well I stripped the pump down last night, all is good with the clutch and pump so I replaced the bearing for the pulley (£23) as the old one had some play in it and I think was the cause of the noise issue.
For reference the original aircon pulley bearing is - Nachi (manufacturer) 30BGS10DST2
The bearing specialists said it wasnt listed as that so wanted measurements.
They are Inner Diam - 30mm
Outer Diam - 52mm
Width - 22mm
The part number that superceeds it is NACHI 30BG5222-2DSE
The original part is showing as available from France but I didnt want to wait.
So the pump is now back on and I am not removing aircon at this time seeing as its like a new pump so very little resistance in the scheme of things.
- - - Updated - - -
thanks for the input all
  • 2 months later...
Outer Diam - 52mm
Width - 22mm
- - - Updated - - -
Nice
 Share
