The supra fuel pump fuse.
FOSTA
 Share
EFI #2 in the engine bay fusebox. 30 amps.
So if I remove that dose it only disable the fuel pump?
For example if I was to hook up a external pump and connect that to the fuel rail and block off the return so the fuel I put through Dosnt just run back into the supra fuel tank would the car start ? Obviously I will set the external fuel pump to the correct pressure.
 Share
