Changing springs and shocks
Lee_e
 Share
Hey guys
Im pretty handy with the spanners and for the life of me couldnt get the shock and spring off my sup this morning, was planning on changing all 4 today but thats really not going to happen.
Has anybody got a guide or can give me a step by step ? i dont really want to undo the upper wishbone due to the bolt being huge (iv heard).
i couldnt seem to find any way of applying leverage etc so the shock would pop out.
Any hope would be awesome :)
I just took the top wishbone bolt out - so much easier to do! yes, its is long, but plenty of WD the night before... comes out relitivly easy!
I do this too, but having a ramp or wheel stands to allow the bolts to be tightened back up with the cars weight on them is essential.
right !!! i have pretty much tried my hardest , both wheels are off ground both wheels are off , has a tiny bit more leverage but i just cant seem to slide it over the lower wishbone,
is there anything i should be loosening etc ... apart from the wishbone which i just cant be dealing with the hassle of takin it off :(
ill givbe you a run by on what i have done so far:
taken wheels off
taken strut brace off from under the bonnet and done bolts back up x3
car on axle stands ( on the chassis )
Taken out the bottom bolt that goes through the bottom of the shock, and now im stuck....
tried taking the top bolts off to allow more play bit it just slides into the holes and jams it ... GRRR
Edited by Lee_e (see edit history)
Me and my bro undid, obviously all the shock bolts then the inside lower arm bolt, then as i applied pressure downwards on the hub he pulled the shock out top end first towards where the wheel sits, it is close to the arch but it comes out changing the shocks have been the easiest thing to do on my car
Did you have a look at this Jim:
http://www.mkivsupra.net/vbb/showthread.php?t=177475
You are supporting the weight of the car on the chassis aren't you?
In other words the suspension is free to drop down until the damper is fully extended.
i have the 3 nuts undone now and its almost as if it just gets to the point where i need a hand pushing it down and prising it out, will have another go now.
The proper way to get it off without mole grips
Pretty much what you have to do because the design is retarded and you'll round the allan key
Off it goes.
Read up TDR's thread, i followed that when mine were done, 3hrs to do one side then 1hr to do the other once i got the jist of it
OK im giving up !! iv taken the drop link bolt out that is shown in the picture above and i still cant apply enough pressure to slide the bottom of the shock over lower wishbone
iv tried doing it from the top and pulling it outwards the arch but no way in hell that can come out like that.
I will leave it for another day or just spend £300 getting it done for me :(
unless anybody local wants to lend a hand ??
Told you, wishbone bolt.
On the passengers side you remove the inner arch at the front and then unbolt the water bottle. This allows you to remove it. Drivers side just comes right out.
You will most likely need a spare pair of hands as you might want to stand on the hub to push it down enough to get the strut out. I did this on my own but it wasn't fun.
 Share
