Guest chrismtaylorsup Posted November 10, 2007 Share Posted November 10, 2007 hi just fitted a set of lightened pulleys to my bpu supra:p and what a diffrance much quicker on pull off and they look wicked . co2 spray bar kit next any 1 else got 1 ??? Link to comment Share on other sites More sharing options...
Ric Posted November 10, 2007 Share Posted November 10, 2007 no they dont thats called placebo Link to comment Share on other sites More sharing options...
RobSheffield Posted November 10, 2007 Share Posted November 10, 2007 Hope you left the crank one alone Link to comment Share on other sites More sharing options...
Guest chrismtaylorsup Posted November 10, 2007 Share Posted November 10, 2007 no changed the crank as it weighs shit loads . lol:eyebrows: Link to comment Share on other sites More sharing options...
Steve Posted November 10, 2007 Share Posted November 10, 2007 no changed the crank as it weighs shit loads . lol:eyebrows: Changed it with what? Have you got a link to which pulleys you bought? Link to comment Share on other sites More sharing options...
michael Posted November 10, 2007 Share Posted November 10, 2007 http://www.neurosybir.net/nkoan/images/fail_label.jpg Link to comment Share on other sites More sharing options...
Ben-san Posted November 10, 2007 Share Posted November 10, 2007 no changed the crank as it weighs shit loads . lol:eyebrows: It has a reason to weigh that much Chris. Link to comment Share on other sites More sharing options...
Steve Posted November 10, 2007 Share Posted November 10, 2007 http://www.neurosybir.net/nkoan/images/fail_label.jpg Link to comment Share on other sites More sharing options...
RobSheffield Posted November 10, 2007 Share Posted November 10, 2007 no changed the crank as it weighs shit loads . lol:eyebrows: Not a good idea, do a readup 'lol' Link to comment Share on other sites More sharing options...
wynter919 Posted November 10, 2007 Share Posted November 10, 2007 if they are just lightened and not underdrived then i dont see how they would make a differance. underdrive pully set would, is that what you meant? Link to comment Share on other sites More sharing options...
Ric Posted November 10, 2007 Share Posted November 10, 2007 no, it isnt Link to comment Share on other sites More sharing options...
Daston Posted November 10, 2007 Share Posted November 10, 2007 Toyota spent a vast amount of money and decided to make the crank pully weigh that much for a reason. Link to comment Share on other sites More sharing options...
wynter919 Posted November 10, 2007 Share Posted November 10, 2007 Toyota spent a vast amount of money and decided to make the crank pully weigh that much for a reason. ? surly you mean the crank itself...never looked into it but surly the engine is balanced internally or with a balancer....does the engine balance come from the crank pully itself?? Link to comment Share on other sites More sharing options...
Homer Posted November 10, 2007 Share Posted November 10, 2007 ? surly you mean the crank itself...never looked into it but surly the engine is balanced internally or with a balancer....does the engine balance come from the crank pully itself?? It's part of a balanced system so if you change it, there is a knock on effect on the crank balance. From what most of the engine builders on here have said it's only worthwhile changing on engines with serious power output where daily/road use isn't a factor. Link to comment Share on other sites More sharing options...
wynter919 Posted November 10, 2007 Share Posted November 10, 2007 It's part of a balanced system so if you change it, there is a knock on effect on the crank balance. From what most of the engine builders on here have said it's only worthwhile changing on engines with serious power output where daily/road use isn't a factor. really...first engine ive heard of like that...changed a few pully sets onto lighter ones on cars before and its not a prob beacuse its either internally balanced or has a harmonic balancer...just because its lighter doesnt actually change any balance as such as no center of gravity has been changed...its just lighter so less work...a crank is specifically balanced in areas to match the desighn of the engine or it is done via a harmonic balancer like the V8's i work on...a pully should not afect this or at least it is the first system ive come accross where a pully is desighned to also balnace the engine. if i am wrong please let me know as i was planning to install my 3-way light and underdrive set on tuesday! if this is the case then i will just install the other 2 and not the crank pully p.s if it is a no no, why do greddy and unorthodox racing to name a few make them for both n/a and TT? Link to comment Share on other sites More sharing options...
Homer Posted November 10, 2007 Share Posted November 10, 2007 Have a search for Digsy's posts in tech regarding crank dampening, they're very informative. p.s if it is a no no, why do greddy and unorthodox racing to name a few make them for both n/a and TT? Because, as mentioned, in racing/extreme high power applications every weight saving makes a difference. Reliability and daily use are not a factor. Plus, it makes them money from people who buy parts because they're "uprated"... it's the same reason HKS sell those awful air filters. Link to comment Share on other sites More sharing options...
wynter919 Posted November 10, 2007 Share Posted November 10, 2007 just read up about it (dual mode damper pulley that toyota use) interesting design good thing i found this out only 2 days before i changed it p.s i can still change the other pullys for the alternator and bits to get the underdrive without problems correct.???????? they have no affect on the balance of the engine.....or is there sum wird deign for them as well lol Link to comment Share on other sites More sharing options...
RobSheffield Posted November 11, 2007 Share Posted November 11, 2007 The other accessory pulleys can be changed Link to comment Share on other sites More sharing options...
