supra_surj Posted November 3, 2007 Share Posted November 3, 2007 Hi guys got a problem when number 2 tubbie comes online. The first spools up nicely, at 4k revs the 2nd turbo comes online. Now usually this will keep going to redline but for the past 2 weeks it stops at 5k. The car starts shaking and juddering and doesnt go past 5k. Would anyone know what this means or what i could check? Im quite worried about this. Quote Link to comment Share on other sites More sharing options...
Homer Posted November 4, 2007 Share Posted November 4, 2007 I've seen a few people mention this problem before but can't recall the cause Is it happening in any gear or just on hard motorway runs? Quote Link to comment Share on other sites More sharing options...
supra_surj Posted November 4, 2007 Author Share Posted November 4, 2007 Mainly on motorways. When it kicks down number 2 normally comes online straight away but this doesnt seem to want to go. Dont drive fast on normal roads so only noticed on motorways. Quote Link to comment Share on other sites More sharing options...
Cass Posted November 4, 2007 Share Posted November 4, 2007 Having the same drama myself (Among other things) After hours of chatting with the people that can ,I'm concentrating my search with either the sub throttle position sensor or the TC actuator. Still not found the source of the drama yet tho Quote Link to comment Share on other sites More sharing options...
supra_surj Posted November 4, 2007 Author Share Posted November 4, 2007 Ive had my car for 2yrs now with not a problem then suddenly this. Im going to check what i can tomorrow. Are you getting the same fault? Quote Link to comment Share on other sites More sharing options...
Cass Posted November 4, 2007 Share Posted November 4, 2007 Yep same thing mate.I ve noticed if i ease of the throttle it boosts,but if the foot is down it judders and shakes and the exhaust splutters and wont rev up high. Sometimes it won't rev at all when static it just idles away. Quote Link to comment Share on other sites More sharing options...
supra_surj Posted November 4, 2007 Author Share Posted November 4, 2007 Thats exactly what im getting. What have you checked so far? Ill do the same checks tomorrow. Quote Link to comment Share on other sites More sharing options...
Homer Posted November 4, 2007 Share Posted November 4, 2007 What boost levels and speeds are you guys seeing when this happens? Is it consistent? Quote Link to comment Share on other sites More sharing options...
Cass Posted November 4, 2007 Share Posted November 4, 2007 Seems to only be boosting stock 0.7 bar rather than 1.2 bar And only about 4000 rpm,roundabout when the 2nd tubby comes online. Ive checked spark plugs,coil pack,throttle position sensor,all vsv's,egcv,vac hoses. Ive even changed my magic tree but didn't work Quote Link to comment Share on other sites More sharing options...
supra_surj Posted November 4, 2007 Author Share Posted November 4, 2007 Mines only stock but at the same boost as cass. Soon at 2nd comes online between 4-5k it struggles. Cass looks like you know more about this stuff than me. Lol I'll have a look today at a few bits. Quote Link to comment Share on other sites More sharing options...
Cass Posted November 4, 2007 Share Posted November 4, 2007 I only know from what I'm suggested to check mate,I'm no guru lol Its just been an on going problem for a while now Unfortunately i think i need to replace my turbos now so i wont know if ive found the problem until that is done or indead if that is the problem. Quote Link to comment Share on other sites More sharing options...
supra_surj Posted November 4, 2007 Author Share Posted November 4, 2007 Thats my worry as well. I really hope the turbos are ok. Quote Link to comment Share on other sites More sharing options...
hiten55 Posted November 4, 2007 Share Posted November 4, 2007 guys, i had this problem at low speeds, have you checked the error codes? also, i cleaned the gearbox sensor, and replaced the gearbox fluid, that fixed it. might not work but id say its definately worth a try Quote Link to comment Share on other sites More sharing options...
supra_surj Posted November 4, 2007 Author Share Posted November 4, 2007 How do i do that? Lol help! Did that sort your problem? Quote Link to comment Share on other sites More sharing options...
hiten55 Posted November 4, 2007 Share Posted November 4, 2007 easy, theres a sensor attached to the side of the gearbox, get under the car, its on the right hand side of the gearbox if you look from the front, pull it out, clean it and put it back. changing the oils even easier - get a mechanic to do it - didnt cause me any issues whatsoever it fixed the problem yeah, but my turbo's were working fine, it was when i started moving off that the revs played up. apparently its caused by dirt in the gearbox meaning the sensor gives incorrect reading and the traction control gets confused or something but its a five minute job and could be worth doing regardles of if it fixes it or not.... but definately check the error codes too... Quote Link to comment Share on other sites More sharing options...
Guest mugg Posted November 4, 2007 Share Posted November 4, 2007 E1-TE1 Code check .....I was too slow with my answer its allready said.....TPS ..Sub Tps also check your connectors at the vsv's and your Tubing...you may have a vacum leak Quote Link to comment Share on other sites More sharing options...
supra_surj Posted November 4, 2007 Author Share Posted November 4, 2007 Thanks guys. Will try to check this today if not may have to be next sat. Recovering from an op so lack of movement. Lol! Quote Link to comment Share on other sites More sharing options...
hiten55 Posted November 4, 2007 Share Posted November 4, 2007 you ok mate? Quote Link to comment Share on other sites More sharing options...
Cass Posted November 4, 2007 Share Posted November 4, 2007 No error codes from me I'll give the sensor a shot as i do have some seepage from the speed selector Gasket thingy. Quote Link to comment Share on other sites More sharing options...
supra_surj Posted November 4, 2007 Author Share Posted November 4, 2007 Yea mate nothing serious, yet anyway. Got all the bits to go bpu but gotta sort this out 1st. I read a few other threads. Gonna reset ecu, go for drive then check error codes. Quote Link to comment Share on other sites More sharing options...
hiten55 Posted November 4, 2007 Share Posted November 4, 2007 keep us informed mate. worth noting, my gearbox fluid was filty, but my sensor looked quite clean.... Quote Link to comment Share on other sites More sharing options...
supra_surj Posted November 4, 2007 Author Share Posted November 4, 2007 Im gonna check my paperwork but im pretty sure i had the gearbox oil changed on last service. Had new plugs put in.was told they are platinum plugs. Are they any good? Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted November 4, 2007 Share Posted November 4, 2007 Cass, i assume you are already BPU ? i know you said your spark plugs are ok but what type are you using ? I had this very same problem when i first changed to BPU, you may not have had the problem to start with but as the weathers got colder this affects the way your car is running and hence only just started getting this problem. i checked my sparks but like yours they seemed in good condition but thought i'd change them anyway which solved the problem straight away. I strongly suggest getting some new spark plugs, try IK24 Irdium sparks. Quote Link to comment Share on other sites More sharing options...
Cass Posted November 4, 2007 Share Posted November 4, 2007 Yep IK24 Irdium sparks fitted this end . Still using the SMIC so not full bpu . Quote Link to comment Share on other sites More sharing options...
supra_surj Posted November 4, 2007 Author Share Posted November 4, 2007 The SMIC would cause that problem would? Quote Link to comment Share on other sites More sharing options...
