Andrew Posted June 17, 2002 Share Posted June 17, 2002 Decided to paint my calipers and noticed that the front calipers are larger than the back calipers. I know that my fronts are UK spec because I had pads fitted a couple of months back. Is it possible that the previous owners had only coverted the front and left the rears, or do the UK specs have small rear calipers? If I do have a mixture, is it safe? Cheers Andrew Link to comment Share on other sites More sharing options...
Branners Posted June 17, 2002 Share Posted June 17, 2002 The UK rears are smaller than the fronts, theres no point in having them the same size as the fronts do most of the braking anyway. So long as they look like a mini version of the UK fronts then they are okay, if they look small with openings near the bottom of the caliper then they might be j-specs. Somebody really needs to take some piccies of the front and rear calipers on UK and imports and then post them in a thread on here so we can all reference back to them. JB Link to comment Share on other sites More sharing options...
Alex Posted June 17, 2002 Share Posted June 17, 2002 Front disc/calipers will always be bigger as the front does 70% of the braking! I believe the UK rears have two piston as opposed to the j-spec 1 piston Link to comment Share on other sites More sharing options...
Dragonball Posted June 17, 2002 Share Posted June 17, 2002 While on the subject of brakes - trying hard to find a set of UK calipers for front and rear Anyone got any leads on sourcing? Or any available following an upgrade etc? Cheers Paul:cool: (ps Sun is shining!!) Link to comment Share on other sites More sharing options...
Andrew Posted June 17, 2002 Author Share Posted June 17, 2002 Thanks guys, puts my mind at rest. Link to comment Share on other sites More sharing options...
Alex Posted June 17, 2002 Share Posted June 17, 2002 Originally posted by Paul E While on the subject of brakes - trying hard to find a set of UK calipers for front and rear Anyone got any leads on sourcing? Or any available following an upgrade etc? Cheers Paul:cool: (ps Sun is shining!!) There is a group buy being arranged in the For Sale/wanted section Link to comment Share on other sites More sharing options...
Terminator Posted June 17, 2002 Share Posted June 17, 2002 There is nothing wrong with running UK fronts and Jap rears. As said above most of the braking ison the fronts when it matters. At low speeds, when braking is more evenly didtributed back and front, the jap rears are perfectly adequate. Link to comment Share on other sites More sharing options...
Matt Harwood Posted June 17, 2002 Share Posted June 17, 2002 I'm running UK front's and J-spec rears. No problems here... Except that my rear disks are warped:( Link to comment Share on other sites More sharing options...
