Today I found out that
Ian C
The 12v fuel pump mod has a use :thumbs:
It really helps the auto shift at WOT with a single turbo. Makes it smoother and minimises the chance of detonation immediately after the gearshift.
Gonna hafta rewrite my scathing commentary on it in the FAQ section now :innocent:
-Ian
-Ian
most interesting, have you any explanation or theorys as to why, do'es anyone else have any input ?
Guest Usmann A
Nice:D
Single cars run twin pumps mostly, they should be relayed seperately, use stock trigger wire, that way its all good and safe.
Cmon now Mr C, thats not upto your usual tuning theory standards .. :D :D
:thumbs:
Twin walbro's off the stock power feed works, although as this thread demonstrates I'm always ready to change my opinions based on evidence:) In fact after what I've seen, two pumps is overkill :eek: Wish I hadn't bothered with two, the fuel system was a major pain in the ass to do :( But we live and learn :)
Dude - yeah, I've recovered, but my stomach is still on the A47 in a layby somewhere heh :)
Anyone who doesn't think an E-Manage can run a single turbo needs to try a properly mapped one, eh Dude? :D
-Ian
Guest Usmann A
Ian, the stock power feed wire, cannot support twin pumps 100%,or when flowing for some serious HP as the wire gauge isnt thick enough, gets too hot, and in some cases can melt the bugger.
Yes twin pumps use less current, but pull more Volts.
But like you say twin pumps overkill for road car, but Id only advise to run each pump off its own relay, and seperate power supplies. Im not having a dig at your method, alot of people use this, I was too, but all depends on what the goal is.
:thumbs:
Assuming the twin pumps are wired in parallel, they will both draw 12V or whatever the supply voltage is across them. However, assuming they require as much power each as a single pump, they will draw more current down the wire up to the point where the wire splits in two.
What is the power rating of the stock pump and the Walboro?
Two Walbros takes about as much current as one UK spec so I think it's gonna be OK but it's something I'm going to keep an eye on anyway :thumbs:
At the first sign of a problem it'll be off to Matt's for the dual wiring :)
-Ian
-Ian
Bloody hell Ian, that was fast :eek:
If that is true, then electrically you should be fine. I'll check out the Walboro specs tomorrow when I pop over if you like.
Guest Usmann A
I was just saying, as I thought you had a BL fuel system, which Terry has told me comes with all the relays, and bits and bobs.
Ian, I didnt mean it to sound cocky. :thumbs:
I'm running some fiendish prototype Vortex Power system that Terry and I specced and built from the ground up :)
No worries A, it was a legit technical concern you had and I'm always willing to be brought up on those :thumbs:
-Ian
surely the fuel computer should b able to handle this? i wouldn't have thought it would drop to 9v for a few milliseconds just on the gear change. even on the twins, it would be a bit of an oversight by toyota if it did. maybe the fuel computer on that car is not working correctly?
Originally posted by Paul Laing
Anyone know if this mod would be worthwhile on a UK spec? My car was running just slightly lean around midrange at Thor and they recommended a SAFC or Emanage to sort this out, but would i benefit from this 12v mod instead?
Paul
Yes - of course that's it indeed...you haven't missed the point at all...
:innocent: :music:
