robin Posted July 24, 2007 Share Posted July 24, 2007 At some point I am looking at increasing the boost so I have been looking at various boost controllers. So far I like the look of the AEM one best. I think it’s a 52mm dial type thing so it should be able to go in place of one of the vents perhaps? I really don’t want to end up with a boost controller hanging out of the dash or glued on top. I would like it to look as subtle and made to fit as possible. Has anyone had any experience with this controller? I've done a quick search and not found anything nasty mentioned. http://www.envyperformance.com/images/stock/304350aa5.jpg Link to comment Share on other sites More sharing options...
DamanC Posted July 24, 2007 Share Posted July 24, 2007 Tis 52mm, will fit nicely where your clock is Link to comment Share on other sites More sharing options...
robin Posted July 24, 2007 Author Share Posted July 24, 2007 Doh! I need that to tell the time... and the temp. Maybe a 52mm hole saw in the right location? Link to comment Share on other sites More sharing options...
suprafan72 Posted July 24, 2007 Share Posted July 24, 2007 At some point I am looking at increasing the boost so I have been looking at various boost controllers. So far I like the look of the AEM one best. I think it’s a 52mm dial type thing so it should be able to go in place of one of the vents perhaps? I really don’t want to end up with a boost controller hanging out of the dash or glued on top. I would like it to look as subtle and made to fit as possible. Has anyone had any experience with this controller? I've done a quick search and not found anything nasty mentioned. http://www.envyperformance.com/images/stock/304350aa5.jpg yeah ive got one in mine now.. once you get the hang of it.. its easy to use, seems to hold boost pretty well... you can read it in bar or psi... and has the usual scramble boost feaures etc.... Link to comment Share on other sites More sharing options...
robin Posted July 24, 2007 Author Share Posted July 24, 2007 does it have presets? I like the idea of having stock or low and high boost. one setting for the normal drives and another for when its needed. Link to comment Share on other sites More sharing options...
suprafan72 Posted July 24, 2007 Share Posted July 24, 2007 does it have presets? I like the idea of having stock or low and high boost. one setting for the normal drives and another for when its needed. Yeah, it has an off (wastegate spring pressure) and a low and hight boost setting.. all easy to swich over.... Link to comment Share on other sites More sharing options...
robin Posted July 24, 2007 Author Share Posted July 24, 2007 Oh nice. So I could do all 3. Off for stock, low and High. Now I just need to work out where to mount it... and uh buy, fit etc. Link to comment Share on other sites More sharing options...
Guest Nicholas Posted July 24, 2007 Share Posted July 24, 2007 Oh nice. So I could do all 3. Off for stock, low and High. Now I just need to work out where to mount it... and uh buy, fit etc. Robin I had mine professionally mounted in place of the stock clock but using the stock clock fittings, fantastic job Link to comment Share on other sites More sharing options...
Homer Posted July 24, 2007 Share Posted July 24, 2007 Seems a bit crap TBH. It only has two presets and a single output, poor display (though okay for AFR). Why not go for one of the better known, proven brands like the SBC-ID models? They at least have decent configuration via the controls on the BC and is easily switched between 4 different modes (not to mention the masses of other config available) Link to comment Share on other sites More sharing options...
robin Posted July 25, 2007 Author Share Posted July 25, 2007 the SBC-ID VIII Boost Controller does look good. I like that you con monitor all the other sensors from the ECU but it is nearly double the price of the AEM and then I have to find a home for the control box thing and a screen. What about the Dual SBC Spec R or the power entrprise one with the analouge gauge? I could proberly hide the SBC Spec R in the spare din slot under the stereo. Link to comment Share on other sites More sharing options...
suprafan72 Posted July 25, 2007 Share Posted July 25, 2007 the SBC-ID VIII Boost Controller does look good. I like that you con monitor all the other sensors from the ECU but it is nearly double the price of the AEM and then I have to find a home for the control box thing and a screen. What about the Dual SBC Spec R or the power entrprise one with the analouge gauge? I could proberly hide the SBC Spec R in the spare din slot under the stereo. It all depends what you want, its nothing too special to be honest but it does the job and thats it..... Theres lots better out there.... with some of the more expensive ones you can have hours of playtime... Link to comment Share on other sites More sharing options...
robin Posted July 25, 2007 Author Share Posted July 25, 2007 Basicly I am after something that does the job and looks good wihtout being too expensive. Maybe asking alot. With the TT do you need anything extra beacause of the two turbos? Or is it all controlled from the one wastegate? Link to comment Share on other sites More sharing options...
robin Posted July 25, 2007 Author Share Posted July 25, 2007 Ordered the AEM. Managed to find it for 190 quid new The down side is now I will have to work out how to program the clock on my stereo as I will soon lose the oem one Link to comment Share on other sites More sharing options...
Guest chrismtaylorsup Posted November 7, 2007 Share Posted November 7, 2007 hi has any 1 got the instructions for useing this ??? i have 1 fitted but dont no how to use it ?? Link to comment Share on other sites More sharing options...
kylestt Posted November 7, 2007 Share Posted November 7, 2007 Try this link, you may have to be a member to save the instruction .pdf file. If the link dont work, its on the AEMpower.com forums under Gauges. http://forum.aempower.com/forum/index.php/topic,17959.msg100755.html#msg100755 Link to comment Share on other sites More sharing options...
Nic Posted November 8, 2007 Share Posted November 8, 2007 What about the Dual SBC Spec R or the power entrprise one with the analouge gauge? I could proberly hide the SBC Spec R in the spare din slot under the stereo. The Blitz SBC Spec R is very good and would be the budget EBC I'd choose. The Power Enterprise boost controller was discontinued a while ago, which is a shame as it looks good. http://img145.imageshack.us/img145/715/picture1kd7.png Link to comment Share on other sites More sharing options...
Gaz Walker Posted November 8, 2007 Share Posted November 8, 2007 The Blitz SBC Spec R is very good and would be the budget EBC I'd choose. The Power Enterprise boost controller was discontinued a while ago, which is a shame as it looks good. http://img145.imageshack.us/img145/715/picture1kd7.png Yeah I agree with Nic. Although the Profec B2 is a nice bit of kit too. I still have one of the PE Boost Controllers in stock! Regards, Gaz. Link to comment Share on other sites More sharing options...
Gaz6002 Posted November 8, 2007 Share Posted November 8, 2007 I've got the AEM tru-boost and think its great. Does the job very well due to the solenoid it uses and looks pretty good too. Link to comment Share on other sites More sharing options...
Gaz Walker Posted November 8, 2007 Share Posted November 8, 2007 I've got the AEM tru-boost and think its great. Does the job very well due to the solenoid it uses and looks pretty good too. For the money, you can't go wrong. It is the cheapest EBC available, works well, perfect for the clock location too Gaz. Link to comment Share on other sites More sharing options...
