r1george Posted July 10, 2007 Share Posted July 10, 2007 Still got the drone in the car even after changing both rear wheel bearings, no oil deposits around diff so probably no lack of oil. 94 TT Auto any ideas?? Has anyone else tried tracking down droning noises, I could end up changing the whole transmission to find the problem and then find out it was a tyre Any help appreciated. Link to comment Share on other sites More sharing options...
Scooter Posted July 10, 2007 Share Posted July 10, 2007 and then find out it was a tyre this may not be far off............i'm sure Muffleman had a bad drone that turned out to be the tyres....... What rear tyres do you have, depending on your wheels it may be possible to swap your fronts and rears temporarily (obviously only worth it if they are different brands!) to see if it makes a difference......... Link to comment Share on other sites More sharing options...
Scooter Posted July 10, 2007 Share Posted July 10, 2007 Mufflemans thread....... . . . . Link to comment Share on other sites More sharing options...
Scooter Posted July 10, 2007 Share Posted July 10, 2007 and here where buying 2 rear tyres sorted his droning....... Link to comment Share on other sites More sharing options...
gaijin Posted July 10, 2007 Share Posted July 10, 2007 Leave wife/girlfriend/boyfriend at home. Link to comment Share on other sites More sharing options...
r1george Posted July 11, 2007 Author Share Posted July 11, 2007 Leave wife/girlfriend/boyfriend at home. Cheers but that drone just follows me everywhere;) Link to comment Share on other sites More sharing options...
r1george Posted July 11, 2007 Author Share Posted July 11, 2007 The tyres are Toyo Proxies and been on for about 18months. Loads of meat left on them and worn evenly but could there noise charateristics change due to wear/age. Also does anyone thing it could be the front wheel bearings?? or maybe front discs as I changed them 6 months ago for the grooved type?? (I didn't notice a drone immediately after changing discs) Does the prop have bearing/s?? Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 11, 2007 Share Posted July 11, 2007 Could be propshaft centre bearing. Has it had an aftermarket LSD fitted? Try borrowing someone elses wheels and tyres? Turn the radio up and forget about it until it becomes more obvious what it is? Link to comment Share on other sites More sharing options...
snake Posted July 11, 2007 Share Posted July 11, 2007 mine drones on a bit when i put my foot down ,but hey its my car and not hers. Link to comment Share on other sites More sharing options...
r1george Posted July 11, 2007 Author Share Posted July 11, 2007 Could be propshaft centre bearing. Has it had an aftermarket LSD fitted? Try borrowing someone elses wheels and tyres? Turn the radio up and forget about it until it becomes more obvious what it is? Cheers Chris, no to the aftermarket LSD as far as I know. Would the prop need removing to check or would it be obvious from under the car?? My brothers got a 300ZX so could try his rear wheels (weekend job I think). Turning the radio sounds like a plan Link to comment Share on other sites More sharing options...
r1george Posted July 11, 2007 Author Share Posted July 11, 2007 mine drones on a bit when i put my foot down ,but hey its my car and not hers. Link to comment Share on other sites More sharing options...
Angarak Posted July 11, 2007 Share Posted July 11, 2007 I have the 'knackered wheel bearing' drone on my car, it increases/decreases with speed, and is more noticeable on certain road surfaces. I've checked the wheel bearings and they're all fine, no play whatsoever. Checked the Diff oil and thats fine, and as far as I know its a standard Torsen LSD. I reckon its my Jap tyres (Bridgestone Potenza RE-01's) that are making the noise. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 12, 2007 Share Posted July 12, 2007 Cheers Chris, no to the aftermarket LSD as far as I know. Would the prop need removing to check or would it be obvious from under the car?? My brothers got a 300ZX so could try his rear wheels (weekend job I think). Turning the radio sounds like a plan You'll need to remove the prop, 15 minutes on a ramp maximum. Link to comment Share on other sites More sharing options...
r1george Posted July 12, 2007 Author Share Posted July 12, 2007 Not looked yet but is the prop a 2 piece, if the centre bearing has gone can it be replaced in my garage or is it a recon prop needed??? Link to comment Share on other sites More sharing options...
