Power Question About UK TT Manual
J33LUS
How much power can be obtained from a standard UK Supra TT Manual by adding:
A Straight Through Exhaust
De-Cat
Uprated Air Filters
Dump Valve
Would like to get 400bhp. What mods would you suggest with a budget of £2000?
Thanks guyz,
You would need to add a boost controller,fcd,colder grade spark plugs and prob an intercooler to that list
That would get you round about 400fwhp
Its reccomended to get a full service and get compression and leakdown tests to make sure your engine is healthy
Someone with more knowledge will be along to give you a more indepth list i expect:):)
You dont need a new fuel pump or intercooler, if the ones currently in there are fine, a boost controller and plugs yes.
Would it not be wise for the sake of £80 ish to change the fuel pump for peace of mind or they reliable and strong?
If you are downgrading to a Walbro I'd say not, if you are spending a bit more and getting a new UK to replace a tired one then perhaps... chances are the old one is still more than up to the job though.
