J33LUS Posted July 4, 2007 Share Posted July 4, 2007 How much power can be obtained from a standard UK Supra TT Manual by adding: A Straight Through Exhaust De-Cat Uprated Air Filters Dump Valve ? Would like to get 400bhp. What mods would you suggest with a budget of £2000? Thanks guyz, Quote Link to comment Share on other sites More sharing options...
edge Posted July 4, 2007 Share Posted July 4, 2007 Spark plugs, boost controller, renew or upgrade fuel pump etc, Check bpu section in forum Quote Link to comment Share on other sites More sharing options...
Supradan Posted July 4, 2007 Share Posted July 4, 2007 You would need to add a boost controller,fcd,colder grade spark plugs and prob an intercooler to that list That would get you round about 400fwhp Its reccomended to get a full service and get compression and leakdown tests to make sure your engine is healthy Someone with more knowledge will be along to give you a more indepth list i expect:) Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted July 4, 2007 Share Posted July 4, 2007 You dont need a new fuel pump or intercooler, if the ones currently in there are fine, a boost controller and plugs yes. Quote Link to comment Share on other sites More sharing options...
edge Posted July 4, 2007 Share Posted July 4, 2007 You dont need a new fuel pump or intercooler, if the ones currently in there are fine, a boost controller and plugs yes. Would it not be wise for the sake of £80 ish to change the fuel pump for peace of mind or they reliable and strong? Quote Link to comment Share on other sites More sharing options...
michael Posted July 4, 2007 Share Posted July 4, 2007 Would it not be wise for the sake of £80 ish to change the fuel pump for peace of mind or they reliable and strong? If you are downgrading to a Walbro I'd say not, if you are spending a bit more and getting a new UK to replace a tired one then perhaps... chances are the old one is still more than up to the job though. Quote Link to comment Share on other sites More sharing options...
colsoop Posted July 4, 2007 Share Posted July 4, 2007 Would it not be wise for the sake of £80 ish to change the fuel pump for peace of mind or they reliable and strong? Uk pump flows better than Walbro IIRC but it is more expensive Beaten to it Quote Link to comment Share on other sites More sharing options...
Thorin Posted July 4, 2007 Share Posted July 4, 2007 Indeed, it's tired old j-spec pumps that are probably a good idea to replace as they flow even less... saying that, mine hasn't been changed. Quote Link to comment Share on other sites More sharing options...
