Pig Posted June 17, 2007 Share Posted June 17, 2007 I bought the Powerhouse racing fuel system, only to discover that the aeromotive fuel filter is too small. Do any of the traders sell bigger ones? I spotted envy sell the AEM one but not sure if they will fit etc. What are some of other singles running? Link to comment Share on other sites More sharing options...
michel lane Posted June 17, 2007 Share Posted June 17, 2007 i sell an AEM fuel filter , you can run the standard -8an lines to it , but i tend to just run 1, -10an line .The filters are quite expensive , £65 with the 2 -8an converters. Its red . Link to comment Share on other sites More sharing options...
Pig Posted June 17, 2007 Author Share Posted June 17, 2007 Is it the same one as on the envy website? I am running - 10 an lines now afaik. Is there one available thats a - 10an? Link to comment Share on other sites More sharing options...
RobSheffield Posted June 17, 2007 Share Posted June 17, 2007 Too small in what way Jon? As in the thread sizes? Link to comment Share on other sites More sharing options...
Pig Posted June 17, 2007 Author Share Posted June 17, 2007 no as in, its about the size of my thumb - greg has informed me it may be restrictive. - What your going to use rob? Im in for mapping up to silly boost so need to sort one asap really Link to comment Share on other sites More sharing options...
RobSheffield Posted June 17, 2007 Share Posted June 17, 2007 IIRC most large singles use the Aero one, but i could be wrong, im just goin to use an aero one but mine will only run amax of 1.4 bar Link to comment Share on other sites More sharing options...
JamieP Posted June 17, 2007 Share Posted June 17, 2007 I use the areomotive one. Link to comment Share on other sites More sharing options...
RobSheffield Posted June 17, 2007 Share Posted June 17, 2007 Post a pic up Jon, its possible you got the wrong one? Link to comment Share on other sites More sharing options...
Pig Posted June 17, 2007 Author Share Posted June 17, 2007 I use the areomotive one. the small one out of the powerhouse racing kits? Link to comment Share on other sites More sharing options...
RobSheffield Posted June 17, 2007 Share Posted June 17, 2007 IIRC Jon the PHR kits will support lots of power (and therefore lots of fuel) Link to comment Share on other sites More sharing options...
Steve Posted June 17, 2007 Share Posted June 17, 2007 Rob i saw the filter at TF (BBQ), it is tiny compared to some of the others. Even compared to stock. Link to comment Share on other sites More sharing options...
JamieP Posted June 17, 2007 Share Posted June 17, 2007 the small one out of the powerhouse racing kits? I dont know what size it is, never had any fueling issues with it though, ran the T88 at 1.8 bar with it. Link to comment Share on other sites More sharing options...
JamieP Posted June 17, 2007 Share Posted June 17, 2007 Have you asked PHR there views on it, surely they would no sell a part for an uprated fuel kit that was not up to the job:search: Link to comment Share on other sites More sharing options...
Pig Posted June 17, 2007 Author Share Posted June 17, 2007 Have you asked PHR there views on it, surely they would no sell a part for an uprated fuel kit that was not up to the job:search: Thats what i thought - seeing as it is the stage 3 kit. Gimmi a min ill put a pic of it up Link to comment Share on other sites More sharing options...
Pig Posted June 17, 2007 Author Share Posted June 17, 2007 here is a link to the fuel system i bought (stage 3): http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=206&SearchYN=N Here is the pic my stuff - fuel system on the right (filter in blue) Link to comment Share on other sites More sharing options...
JamieP Posted June 17, 2007 Share Posted June 17, 2007 Hard to tell from the pic but im sure mine is bigger than that, size wont matter though its flow that will matter, as long as its the right size fitting i cant see it being an issue. Link to comment Share on other sites More sharing options...
michel lane Posted June 17, 2007 Share Posted June 17, 2007 You can change the fitment at the end , just purchase an adapter ranging from -6 to -12an . Link to comment Share on other sites More sharing options...
bolarbag Posted June 18, 2007 Share Posted June 18, 2007 What fuel system, is that Pig? Stage 1 or 2? Link to comment Share on other sites More sharing options...
Pig Posted June 18, 2007 Author Share Posted June 18, 2007 What fuel system, is that Pig? Stage 1 or 2? Stage 3 Link to comment Share on other sites More sharing options...
bolarbag Posted June 19, 2007 Share Posted June 19, 2007 Stage 3 You went for 960's! WTF! Wot turbo you running? Have you confirmed with phr that the fuel filter is adequate? Surely if its one of their biggest fuel systems they would supply an adequate filter? Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 20, 2007 Share Posted June 20, 2007 Suddenly remembered I have some of these proper race fuel filters, dismantlable, with Aeroquip hose fittings. A fortune new, these have done 2 hours on an engine dyno only, on a Judd race engine. The dyno has its own filtration, these filters were there to check there flow on a 700 HP engine (they were fine). 60 quid plus P&P http://www.chriswilson.tv/filter.jpg Link to comment Share on other sites More sharing options...
ajazyasin Posted June 20, 2007 Share Posted June 20, 2007 Aeroq filters are not restrictive at all. Take all the fittings off and you will see what i mean. you can look stright through it. There is only one very fine mesh inside. Also you can dismantle it for cleaning. Im running 2 of these filters, one for each feed. Link to comment Share on other sites More sharing options...
Pig Posted June 20, 2007 Author Share Posted June 20, 2007 Aeroq filters are not restrictive at all. Take all the fittings off and you will see what i mean. you can look stright through it. There is only one very fine mesh inside. Also you can dismantle it for cleaning. Im running 2 of these filters, one for each feed. Hmm, interesting - i wish i would get one answer sometimes Chris - You have a pm Link to comment Share on other sites More sharing options...
gaz1 Posted June 20, 2007 Share Posted June 20, 2007 Hmm, interesting - i wish i would get one answer sometimes Chris - You have a pm ask more people the same question then and go with who you trust;) Link to comment Share on other sites More sharing options...
