RobSheffield Posted May 24, 2007 Share Posted May 24, 2007 Try as i might i cant get my EPC to do anything other than lock my machine up Need part numbers for:- Heater matrix to back of cyl head rubber pipe Exhaust manifold gasket Inlet manifold lower runners to head Inlet lower runners to inlet manifold, Inlet manifold to throttle body Link to comment Share on other sites More sharing options...
colsoop Posted May 24, 2007 Share Posted May 24, 2007 Try as i might i cant get my EPC to do anything other than lock my machine up Need part numbers for:- Heater matrix to back of cyl head rubber pipe Exhaust manifold gasket (see attached pic is that the gasket you mean ? Inlet manifold lower runners to head Inlet lower runners to inlet manifold, Inlet manifold to throttle body See attached to confirm we are talking about the same parts Rob. Inlet manifold to throttle body is 22271-46030 Link to comment Share on other sites More sharing options...
RobSheffield Posted May 24, 2007 Author Share Posted May 24, 2007 Cheers col Its the lower of the 2 pipes in the diagram (i think) and yes those gaskets, plus the one inlet manifold to TB Link to comment Share on other sites More sharing options...
colsoop Posted May 25, 2007 Share Posted May 25, 2007 Ok part numbers are: 17173-46040 gasket exhaust manifold to head. 17178-46010 gasket exhaust manifold to head no 2. 17177-46031 gasket intake manifold to head. 17176-46030 gasket air surge to intake manifold. 22271-46030 gasket inlet manifold to throttle body. 87209-14800 Hose sub assy water. Link to comment Share on other sites More sharing options...
RobSheffield Posted May 25, 2007 Author Share Posted May 25, 2007 Many thanks Col Link to comment Share on other sites More sharing options...
RobSheffield Posted August 1, 2007 Author Share Posted August 1, 2007 Could i also get the part number for the water elbow on the left of the block (the one you chromed for me ) Its the gasket between the block and the elbow Link to comment Share on other sites More sharing options...
RobSheffield Posted August 5, 2007 Author Share Posted August 5, 2007 Could i also get the part number for the water elbow on the left of the block (the one you chromed for me ) Its the gasket between the block and the elbow Just to clarify that is the gasket part number i need, NOT the part number for the water elbow... Link to comment Share on other sites More sharing options...
Homer Posted August 5, 2007 Share Posted August 5, 2007 This bit? 16343-46030 Link to comment Share on other sites More sharing options...
RobSheffield Posted August 5, 2007 Author Share Posted August 5, 2007 Thats the one sir, thanks very much! Right, now to send some PMs and get some prices on this lot - time to get the damn thing running Link to comment Share on other sites More sharing options...
RobSheffield Posted August 26, 2007 Author Share Posted August 26, 2007 Erm, one last one please Homer/Colsoop Hose from the side/back of the block (TT i think) that goes up and over towards back of the block area Might be worth posting a screenshot as Homer did so i can confirm it... If no replies in next couple of days ill post a pic of the pipe from the BL walkthrough, but i dont have it here with me now Link to comment Share on other sites More sharing options...
Homer Posted August 26, 2007 Share Posted August 26, 2007 This bit Rob (goes over the top of the cylinder head?) 87209-14810 HOSE SUB-ASSY, WATER, D Link to comment Share on other sites More sharing options...
RobSheffield Posted August 26, 2007 Author Share Posted August 26, 2007 I think thats one of the heater matrix hoses isnt it Darryl? Its one that went behind/around the stock 2nd turbo, from the hard pipe that runs from water pump back, the hard pipe has 2 exits on it, one for stock TT tub 2 water feed and one that then goes up past tub and over. From this bit here on the left (open steel pipe)... Link to comment Share on other sites More sharing options...
Homer Posted August 26, 2007 Share Posted August 26, 2007 There's a short rubber pipe that connects to another short metal pipe that then goes to the hose I posted earlier. If this the one (I needed to replace this on mine too!): Link to comment Share on other sites More sharing options...
RobSheffield Posted August 26, 2007 Author Share Posted August 26, 2007 Thats the one sir So its 16282 (and 16279 if i cant find the steel pipe!) Are those the full numbers? Link to comment Share on other sites More sharing options...
Homer Posted August 26, 2007 Share Posted August 26, 2007 The part number is 16282-46010 for the rubber hose, 16279-46010 for the steel pipe Link to comment Share on other sites More sharing options...
RobSheffield Posted August 28, 2007 Author Share Posted August 28, 2007 This is the steel pipe on PHRs site.... And this is from the BL install instructions Link to comment Share on other sites More sharing options...
RobSheffield Posted September 8, 2007 Author Share Posted September 8, 2007 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=58029&d=1180023735 I need the full part number for the one on the bottom left, looks like 87245a but need he rest. PMd col but his EPC is down, and i cant find it on mine Link to comment Share on other sites More sharing options...
RobSheffield Posted September 11, 2007 Author Share Posted September 11, 2007 This bit Rob (goes over the top of the cylinder head?) Homer, i cant find that bit on my EPC, and i dont know why Can you let me know the part number on the one on the lower left, elbow that goes to the water inlet/output on the back of the head. Link to comment Share on other sites More sharing options...
RobSheffield Posted September 11, 2007 Author Share Posted September 11, 2007 Sorted, i think its 87245-1b360 Link to comment Share on other sites More sharing options...
shaz2010 Posted October 20, 2017 Share Posted October 20, 2017 Old thread but in need of the hose that comes off the heater matrix ( engine bay side ) hard pipe as well ! Does anyone know if Toyota still do these ? Ta Link to comment Share on other sites More sharing options...
