Greddy E-manage Blue.
SupraPL
I will need also the injector harness and the pressure sensor and harness. I'm right?
Make sure the unit has the full main harness wiring, not the half wiring like some versions have
As mentioned, yes. You need the injector harness and pressure sensor. I found Nic to be to the best price for these, but they are not cheap - the pressure sensor was aound £70 alone. I imagine the injector harness to be much the same.
A wideband will be needed for the mapping (If you have an existing one from an AFR gauge you can simply tap into that), I can't see how it's possible to map without one :blink:
Maybe i should buy Greddy Emanage Ultimate as this has the ability to do timing as well...
EMB can do the timing. But if you can afford it, the EMU is a better choice... and AEM/Motec if you can afford that!
edit - too slow!
