broomie Posted April 16, 2007 Share Posted April 16, 2007 my clutch its way out started slipping this weekend sods law just before the pod, still gonna take it just tip toe there and back! need to replace clutch as cheap as possible as moneys tight at the moment anyone had any experience of these? http://cgi.ebay.co.uk/TOYOTA-SUPRA-3-0-3-0-TURBO-FAST-ROAD-CLUTCH_W0QQitemZ260107977227QQihZ016QQcategoryZ10428QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
Konrad Posted April 16, 2007 Share Posted April 16, 2007 my clutch its way out started slipping this weekend sods law just before the pod, still gonna take it just tip toe there and back! need to replace clutch as cheap as possible as moneys tight at the moment anyone had any experience of these? http://cgi.ebay.co.uk/TOYOTA-SUPRA-3-0-3-0-TURBO-FAST-ROAD-CLUTCH_W0QQitemZ260107977227QQihZ016QQcategoryZ10428QQssPageNameZWDVWQQrdZ1QQcmdZViewItem If you consider cost of changing it (around 150 pounds) plus all the bits and boobs which need to be changed WITH clutch, I would just drive a little longer with slipping clutch and then change it to proper and more expensive one. Do not budget on mechanical parts... If you want to save money, save them on interior by doing DIY, but not engine, transmission or brakes... Quote Link to comment Share on other sites More sharing options...
broomie Posted April 16, 2007 Author Share Posted April 16, 2007 how long do the clutches generally last after they start slipping? Quote Link to comment Share on other sites More sharing options...
miko_supra Posted April 16, 2007 Share Posted April 16, 2007 depends how you drive i guess. My mate went about a month on a slipping clutch on his mr2 Quote Link to comment Share on other sites More sharing options...
Nic Posted April 16, 2007 Share Posted April 16, 2007 how long do the clutches generally last after they start slipping? Not sure on an NA, but on a TT not very long at all. Try to avoid it slipping when driving as a slipping clutch will generate a lot of heat which could damage your flywheel. If you can't drive it without it slipping, don't drive it at all. I'd agree with advice above, fit genuine Toyota parts it you can. Quote Link to comment Share on other sites More sharing options...
broomie Posted April 16, 2007 Author Share Posted April 16, 2007 it tends to only slip above 3500-4000rpm im gonna try not to use it this week but i think im gonna risk taking it to the pod on sat i only live 35 miles away! so its a 70mile round trip! fingers crossed for me! Quote Link to comment Share on other sites More sharing options...
patrikbrunt Posted April 17, 2007 Share Posted April 17, 2007 im in the same situation clutch slips in high gears at low revs... also been looking at that clutch on ebay. the suggestion was to go with genuine toyota parts... but where do you get a toyota clutch kit ? and how much more is that? Quote Link to comment Share on other sites More sharing options...
Konrad Posted April 17, 2007 Share Posted April 17, 2007 Contact Steve Manley - he can manage good price for OEM Toyota parts, or Nic - our import pimp Quote Link to comment Share on other sites More sharing options...
