advice on buying a supra i have seen
Guest benny boy
 Share
In short it could mean a few things:
1) 97 import with the entire exterior converted to UK spec (I would question why? - accident?)
2) UK Spec wrongly registered, with interior replaced
3) It's been ringed/nicked at some point in it life
Get a pic of the VIN plate and /or note down ALL details from it, this can be decoded on here to tell you exactly what it is (assuming it's not option 3 above)
  • Replies 70
This is a bit of a strange one.
The car started out as a red model and then had a colour change. It had a recorded mileage of 105,000 in 2002 so the latest mileage figure doesn't stack up. It has also had 7 previous owners.
It is not showing as accident recorded or stolen and says manufactured in 1997 and not an import - but that also could be a mistake as the DVLA have been known to make mistakes.
I personally would not go for this as there are too many ambiguities.
CJ has the background as always, good of you to post up Col :thumbs:
If Gary still wants to go and check it out at the weekend the paint problem should show up right away (pull some trim Gary ;) ), plus the VIN details will clearly show the paint code, year of manufacture, spec, etc.
Gary, if you want to do a VIN check while you're there give me a call.
Guest benny boy
i've just spoken to the chap, and arranged to go and see it on friday. he hasn't had the car for long and doesn't know anything about its history. the only service history is at 100km (29/11/2001) with service and cambelt change.
chassis number is: jza 8000 78 929
engine number is: 1jz 4532
the V5 just names it as a Toyota Supra.
can anything be identifed from this?
Guest benny boy
ok, i've just been to see the car with Gary, (mr Lover)
Its got big brakes, wheels and all the uk bodywork and badges, its got the small rad in the drivers side rear wheel vent, its dildos work. theres heated seat switchs but the seats don't heat, they are cloth. theres a factory fitted rear fog switch that works the uk spec reak lights.
its got a uk spec engine, the casting has a raised bit on the top of the inlet to one side, not in the centre. all the writing on the sunvisors etc is in english,
the vin plate numbers are:
E-JZA80AJPVF
2JZ GTE
JZA800078929
1JZ 4532
COLOR 202
TRIM LH40
A340EA01A
A22
The V5 does not mention import or date of manufacte.
there is no sign of it being any other color anywhere, and theres no signs of bent metal behind the bumpers.
Now what do you reckon?
Any help is greatly appreciated.
Thanks gary for you time and help.
Country E = Japan
Body J = Aerotop
Gearbox P = 4-speed automatic
Grade V = SZ or RZS
Engine F = EFI & DOHC
2JZ = Twin cam 24 valve inline 6
GTE = Twin turbo
Transmission
A340E = 4-speed auto
Final drive
A = 138mm ring gear
01 = 4.083:1 ratio
A = Standard (non LSD)
Production date = April-97
Colour 202 = Black
Thats what the VIN says sorry for the poor lay out. Not sure about the Trim tho
E-JZA80AJPVF
2JZ GTE
JZA800078929
1JZ 4532
COLOR 202
TRIM LH40
A340EA01A
A22
that model code is for an aerotop ?????????????
Trim Codes
FD12 = Gray Cloth (86.5)
FD32 = Red Cloth (1986.5)
FD82 = Dark Blue Cloth (87)
FJ12 - Gray Cloth (90)
FX21 = Black Cloth (82-83)
FX81 = Blue Cloth (84)
FW81 = Light Blue Cloth (82 L-Type)
GL36 = Maroon Leather(85)
GL81 = Dark Blue Cloth (82-83 L-Type)
GR26 = Gray Cloth (84)
GR36 = Maroon Cloth (85)
GR86 = Blue Cloth (85)
GQ86 = Blue Cloth (85 L-Type)
HB85 = Blue Cloth (81)
LB12 = Gray Leather (87)
LD15 = Shadow Gray Leather (92)
LF21 = Black Leather (83 L-Type)
LG24 = Gray Leather (85-86)
LG26 = Gray Leather (85)
LG36 = Maroon Leather (85-86)
LG86 = Blue Leather (85-86)
LJ81 = Blue Leather (79)
YS34 = Maroon Cloth (84)
YS84 = Light Blue Cloth (84 Performance)
YW41 = Tan Cloth (79)
YW45 = Tan Cloth (80)
YW85 = Blue Cloth (80)
I thought this covered all trims??
 Share
