Erection Problems....
Supragaz
[sHOCK][/sHOCK]
My Aerial decided to stay in the upright position yesterday and is now making a groaning noise when I turn the radio off :(
I have used the search button to see the best replacement but couldnt find an answer.
Is there a way to get the aerial back down again if I disconnect it because I dont normally use it so will be happy if it stays in the down position or do I need a new one?
I would be happy with a direct replacement stubby job If I could find one that fits without modification :(
Thanks
Gaz :)
The motor is louder than normal tho mate, Will try what you suggested tho thanks.
What bits do I grease up :blink:
the actual arial, get some wd40 on it from top to bottom, leave it for a few minutes and then try it. if that doesnt work its the motor id guess.
Sounds like you definetly need a new one mate, as mine went exactly the same. Stayed up and a horrid whirring/grinding noise when i turned the stereo on. Theres a white plastic piece full of teeth, its most likely snapped. I suspect your motor will be fine (mine was) you just need a new mast and plastic piece with teeth that go with it, got mine from Steve Manley for about £30
See this thread for how to do it
http://www.mkivsupra.net/vbb/showthread.php?t=80078&highlight=aerial
