JamieP Posted February 14, 2007 Author Share Posted February 14, 2007 sounds like waste gate leaking mate have you checked the manifold for any cracks around the take off for it ? Yea its the last thing to try, gonna strip it all down on saturday. And yea your right about the afr's i think, now it has extra air it was losing it has thrown the map out. Quote Link to comment Share on other sites More sharing options...
AshBhp Posted February 14, 2007 Share Posted February 14, 2007 I think your waist-gate spring is weak, plus you should change it to 1.2 bar spring. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 14, 2007 Author Share Posted February 14, 2007 I think your waist-gate spring is weak, plus you should change it to 1.2 bar spring. Yea its deffinatly something to try but strange how it was perfect. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 14, 2007 Author Share Posted February 14, 2007 In theory it will try and generate more boost in higher gears due to the extra load on the engine. What boost was it holding in each gear running from the just the wastegate set to 0.8bar? On just the wastegate spring it was holding 0.8bar in everygear but still laggy. Quote Link to comment Share on other sites More sharing options...
michel lane Posted February 14, 2007 Share Posted February 14, 2007 change your pipes to the wastegate first jamie ,i had the same problem about a year ago, turned out they was some muck in the pipe and it went into the top of the wastgate causing the diaphram not to move ... hope you get it fixed. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 14, 2007 Author Share Posted February 14, 2007 Thanks for the suggestions, ill try that. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 17, 2007 Author Share Posted February 17, 2007 All fixed, turned out to be problem with the wastegate, im running modified XS power one for the time being. Thanks for the help:) Quote Link to comment Share on other sites More sharing options...
Pig Posted February 17, 2007 Share Posted February 17, 2007 What was the prob with the wastegate Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 17, 2007 Author Share Posted February 17, 2007 I dont know mate, stripped it down and it all looked fine:search: Quote Link to comment Share on other sites More sharing options...
Pig Posted February 17, 2007 Share Posted February 17, 2007 Hmmmmm, i dont suppose you will ever know then??? Quote Link to comment Share on other sites More sharing options...
Homer Posted April 12, 2007 Share Posted April 12, 2007 Jamie, have you done a boost leak test. Check the link out http://www.boostcreeps.com/phpBB/boostleaktester.php Sorry to resurrect this thread, but the link doesn’t work for me anymore. Does anyone have another or can explain exactly how the system is pressurised? Can it be done with a foot pump too? Quote Link to comment Share on other sites More sharing options...
JamieP Posted April 13, 2007 Author Share Posted April 13, 2007 Greg had a cap made up that clamped onto the turbo inlet, then pumped up with air to pressure and watched for air leaks, its pretty simple bud, should be able to do something with a foot pump and cut up an old innertube and clamp that over i rekon:) Quote Link to comment Share on other sites More sharing options...
terribleturner Posted April 13, 2007 Share Posted April 13, 2007 Sorry to resurrect this thread, but the link doesn’t work for me anymore. Does anyone have another or can explain exactly how the system is pressurised? Can it be done with a foot pump too? Darryl i found another link in google somewhere. Have a 4inch cap made up at home but couldn't find an airline Was going to use the tyre machine at a garage but they all have silly fittings. Foot pump would take forever and wouldn't be that good i don't think. Quote Link to comment Share on other sites More sharing options...
Homer Posted April 13, 2007 Share Posted April 13, 2007 Thanks guys. Change of plan, I'm heading up to Turbofit tomorrow to get it checked there Quote Link to comment Share on other sites More sharing options...
absz Posted April 14, 2007 Share Posted April 14, 2007 Sorry to resurrect this thread, but the link doesn’t work for me anymore. Does anyone have another or can explain exactly how the system is pressurised? Can it be done with a foot pump too? i was looking for the same link earlier today:rolleyes: cannot get the car to boost over 0.6 bar after fitting new injectors and rail. managed a 1.0bar last nite on the motorway with 6500rpm:search: Quote Link to comment Share on other sites More sharing options...
AshBhp Posted April 14, 2007 Share Posted April 14, 2007 Sorry to resurrect this thread, but the link doesn’t work for me anymore. Does anyone have another or can explain exactly how the system is pressurised? Can it be done with a foot pump too? Try this quit ingenues, http://www.supraforums.com/forum/showthread.php?t=78644 Quote Link to comment Share on other sites More sharing options...
