CJ Posted January 30, 2007 Share Posted January 30, 2007 Which programs do you people recommend to optimise the running performance of your PC's? Preferably shareware Link to comment Share on other sites More sharing options...
Pete Posted January 30, 2007 Share Posted January 30, 2007 CPU replacement v1.1 - It involves removing your case, taking out your CPU, then putting in a faster one. Link to comment Share on other sites More sharing options...
CJ Posted January 30, 2007 Author Share Posted January 30, 2007 CPU replacement v1.1 - It involves removing your case, taking out your CPU, then putting in a faster one. Methinks that might be an option. How much do these new fangled things cost? Link to comment Share on other sites More sharing options...
CJ Posted January 30, 2007 Author Share Posted January 30, 2007 I currently have: AMD Athlon XP 2200+ 1.65GHz - 512 MB Ram Link to comment Share on other sites More sharing options...
RobSheffield Posted January 30, 2007 Share Posted January 30, 2007 I can sell you a faster one for £17,000 Link to comment Share on other sites More sharing options...
CJ Posted January 30, 2007 Author Share Posted January 30, 2007 I can sell you a faster one for £17,000 Bargain! Where do I sign? Link to comment Share on other sites More sharing options...
hiten55 Posted January 30, 2007 Share Posted January 30, 2007 CPU replacement v1.1 - It involves removing your case, taking out your CPU, then putting in a faster one. Link to comment Share on other sites More sharing options...
hiten55 Posted January 30, 2007 Share Posted January 30, 2007 or try Linux Link to comment Share on other sites More sharing options...
Konrad Posted January 30, 2007 Share Posted January 30, 2007 I currently have: AMD Athlon XP 2200+ 1.65GHz - 512 MB Ram It's enough unless your second job is graphic designer and you need to render stuff in 3D studio Max Add 1 GB of RAM and SATA HDD if your mainboard is compatibile with SATA and you should be fine. Reinstalling system on computer after 3 years of using it can help also Btw. what makes you think your computer is "slow" ? Link to comment Share on other sites More sharing options...
Gamer Posted January 30, 2007 Share Posted January 30, 2007 I currently have: AMD Athlon XP 2200+ 1.65GHz - 512 MB Ram You will be limited by your motherboard. You need to check what is the highest speed processor it can support. Probably not what you want to hear but to see some real performance gains you would be better off selling the set-up you have now and getting something that is a bit newer. That processor was released in 2001-2002, 5 years in computer terms is almost a lifetime. Link to comment Share on other sites More sharing options...
Pete Posted January 30, 2007 Share Posted January 30, 2007 Reinstall windows - you'll be amazed how much quicker it is. Defrag? Getting hold of Diskkeeper is a good benefit. Windows XP really needs 1Gb - I'd upgrade the RAM first. Maybe a bigger faster hard drive. Link to comment Share on other sites More sharing options...
CJ Posted January 30, 2007 Author Share Posted January 30, 2007 Thanks for all the advice chaps Link to comment Share on other sites More sharing options...
RedM Posted January 30, 2007 Share Posted January 30, 2007 Have you tried resetting the ECU? Link to comment Share on other sites More sharing options...
Daston Posted January 30, 2007 Share Posted January 30, 2007 If you download a little program thats called CPU-Z it will tell you all about your system ie the make and modle of motherboard. You can then search their website to find out what CPU's it supports, if it supports a faster one you may well beable to get an old XP chip off ebay for £20 Link to comment Share on other sites More sharing options...
CJ Posted January 30, 2007 Author Share Posted January 30, 2007 If you download a little program thats called CPU-Z it will tell you all about your system ie the make and modle of motherboard. You can then search their website to find out what CPU's it supports, if it supports a faster one you may well beable to get an old XP chip off ebay for £20 Oh, that sounds like a plan Link to comment Share on other sites More sharing options...
CJ Posted January 30, 2007 Author Share Posted January 30, 2007 Does this mean anything to anyone? Link to comment Share on other sites More sharing options...
Daston Posted January 30, 2007 Share Posted January 30, 2007 damn havnt got word on my pc so cant view it Link to comment Share on other sites More sharing options...
geoffvalenti Posted January 30, 2007 Share Posted January 30, 2007 TBH Col, the amount of difference you'd notice upgrading that motherboard to the fastest CPU it could run, is negligible. Its a bit like taking a Mk3 N/A Supra, and by sticking in the most powerful engine available at the time, trying to make it run like Mkiv TT Link to comment Share on other sites More sharing options...
CJ Posted January 30, 2007 Author Share Posted January 30, 2007 TBH Col, the amount of difference you'd notice upgrading that motherboard to the fastest CPU it could run, is negligible. Its a bit like taking a Mk3 N/A Supra, and by sticking in the most powerful engine available at the time, trying to make it run like Mkiv TT Ah...bugger it then, I will leave things alone. TBH, I was bored today hence the meddling. I should really leave things alone eh? BTW, I got your text and have one sitting here waiting to be used. I could probably do next week if that is any good to you - any day bar Friday. Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted January 30, 2007 Share Posted January 30, 2007 for now if you want a speed up you could turn off all the flashy xp bits so it runs fairly basic visuals, also maybe up the virtual memory Link to comment Share on other sites More sharing options...
CJ Posted January 30, 2007 Author Share Posted January 30, 2007 for now if you want a speed up you could turn off all the flashy xp bits so it runs fairly basic visuals, also maybe up the virtual memory I think I will leave well enough alone chaps. I am bound to bugger it up if I start to fiddle with things Link to comment Share on other sites More sharing options...
geoffvalenti Posted January 30, 2007 Share Posted January 30, 2007 BTW, I got your text and have one sitting here waiting to be used. I could probably do next week if that is any good to you - any day bar Friday. Wednesday or Thursday would be OK for me, You choose Link to comment Share on other sites More sharing options...
CJ Posted January 30, 2007 Author Share Posted January 30, 2007 Wednesday or Thursday would be OK for me, You choose I am meeting with someone on Thursday and they may want to meet up again next week so if it allright with you, I will let you know Thursday evening. Link to comment Share on other sites More sharing options...
geoffvalenti Posted January 30, 2007 Share Posted January 30, 2007 Thats fine Col, just send me a text, I'll try and keep both days free Link to comment Share on other sites More sharing options...
