adi2009 Posted January 12, 2007 Share Posted January 12, 2007 Recently I was getting my 2JZGE engine removed in order to install thicker headgaskets and in the process though that I would get the heads ported. However, the guys that disassembled the head seem to have messed up and I am now left with 22 bent valves. What can be done, do I need to get all new valves or can i get used valves from someone? Link to comment Share on other sites More sharing options...
crashoverride Posted January 12, 2007 Share Posted January 12, 2007 Tell the place where you had the work done to bloody sort it out, i would be furious /vbb/images/smilies/bbcode_angry.gif Link to comment Share on other sites More sharing options...
Bob Posted January 12, 2007 Share Posted January 12, 2007 If they damaged your head, it's up to them to put it right. And if they're damaging valves like that, they shouldn't be allowed anywhere near an engine bay. Link to comment Share on other sites More sharing options...
Guest DaveH Posted January 12, 2007 Share Posted January 12, 2007 If they made a mistake they should buy you new valves (altho used ones would work fine also). DaveH Link to comment Share on other sites More sharing options...
Ian C Posted January 12, 2007 Share Posted January 12, 2007 If they damaged your head, it's up to them to put it right. And if they're damaging valves like that, they shouldn't be allowed anywhere near an engine bay. Those two statements are mutually exclusive I would get them to pay for someone else (eg Chris Wilson) to fix, including the postage. I've no idea if it's possible to fix, there is probably damage to the head itself now and you've got to factor in any machine work they did being completely rubbish. In which case, new cylinder head + valvetrain please, or it's county court time. -Ian Link to comment Share on other sites More sharing options...
SimonB Posted January 12, 2007 Share Posted January 12, 2007 How the hell do you manage to bend 22 valves all at once! What a bunch of muppets! Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 12, 2007 Share Posted January 12, 2007 How do you bend 22 valves DISASSEMBLING a head? Quite a feat, IMO Link to comment Share on other sites More sharing options...
Bob Posted January 12, 2007 Share Posted January 12, 2007 Maybe they took it apart with a hammer and chisel? Link to comment Share on other sites More sharing options...
geoffvalenti Posted January 12, 2007 Share Posted January 12, 2007 How do you bend 22 valves DISASSEMBLING a head? Quite a feat, IMO Well at least someone was doing something this time. In the last thread about bent valves, they apparently bent themselves overnight Link to comment Share on other sites More sharing options...
adi2009 Posted January 14, 2007 Author Share Posted January 14, 2007 So would it be ok if I install a set of used valves from another engine? if so, would I need to change the valve guides? Link to comment Share on other sites More sharing options...
