Chiefgroover Posted January 11, 2007 Share Posted January 11, 2007 Does anyone know are these pruely cosmetic, or do they actually stiffen the shell to a marked degree that merits purchase? Link to comment Share on other sites More sharing options...
Scooter Posted January 11, 2007 Share Posted January 11, 2007 aren't these mainly for aerotops? (where i think from memory of old postings that they do work well) Link to comment Share on other sites More sharing options...
Max Headroom Posted January 11, 2007 Share Posted January 11, 2007 Anything that helps stiffen a floppy aerotop must be good, although on a full bodied Supe the is less "flex" in the body so no much of a need I would say Link to comment Share on other sites More sharing options...
bondango Posted January 12, 2007 Share Posted January 12, 2007 Fundementally will work on either body but as the Aero needs all the help it can get, they make their home in more of them. Can also be used as a Harness bar too Ernie as I think the Do-luck sits above the carpet - so saves running a Harness bar in the car aswell. Link to comment Share on other sites More sharing options...
Nic Posted January 12, 2007 Share Posted January 12, 2007 Does anyone know are these pruely cosmetic, or do they actually stiffen the shell to a marked degree that merits purchase? Ernie, Carbing make these for Do-Luck (they sell the exact same model under their own brand). I supplied this one to an aerotop owner who reported a marked reduction in chassis flex, I've never tested one personally though, so not sure how much effect it would have on a hardtop. Carbing also do 4 and 5 point rear roll cages. http://img406.imageshack.us/img406/3180/cimg0002bs2.jpg http://img242.imageshack.us/img242/6366/cimg0005ah4.jpg Link to comment Share on other sites More sharing options...
Ian C Posted January 12, 2007 Share Posted January 12, 2007 Does anyone know are these pruely cosmetic, or do they actually stiffen the shell to a marked degree that merits purchase? I'd say no. They are bolt-in, so there is a flex point there, the big hoopy bit is another couple of flex points, and it's not a diagonal so what floorpan flex precisely is it supposed to be stopping? I know one aerotop owner was very vociferous that it improved matters no end but then some people think a front strut brace stiffens up an aerotop It might make *some* weeny difference, but the question is "to a marked degree that merits purchase" so my vote is a "no". -Ian Link to comment Share on other sites More sharing options...
T2 MSW Posted January 15, 2007 Share Posted January 15, 2007 Having tested one of these on my own aerotop i can say they do make a big difference but only with the top off. With the top on it makes hardly any noticanle difference. The flex on the rear end was noticable even over small bumps in the road, once fitted it was greatly reduced. It will not iradicate the flex though large bumps still effect the back of the car. In my opinion anyone who has tried these on an areotop and said it makes sod all difference is because they did not have it ajusted correctly. Unfortunatly I had to send mine back to the supplier due to an issue in the mount bracket but im awaiting my replacement from Carbing. Link to comment Share on other sites More sharing options...
Lebsteif Posted January 19, 2007 Share Posted January 19, 2007 Kick, Does Carbing make the Do-Luck Floor Support Bars as well? http://www.mvpmotorsports.com/Merchant//catalogpics/mk4/doluck/80floorsupportbar.jpg And are these things making a great improvement? Link to comment Share on other sites More sharing options...
Nic Posted January 20, 2007 Share Posted January 20, 2007 Kick, Does Carbing make the Do-Luck Floor Support Bars as well? [qimg]http://www.mvpmotorsports.com/Merchant//catalogpics/mk4/doluck/80floorsupportbar.jpg[/qimg] And are these things making a great improvement? Yes Carbing also make these, I haven't supplied any of these yet, so I'm not sure what improvement they make. http://www.okuyama-go.to/products/floor/image/240/1000140.jpg Link to comment Share on other sites More sharing options...
Guest dee_rz Posted January 20, 2007 Share Posted January 20, 2007 nic how much can you get one of those braces that you have shown in pic, do luck has the same type that goes across the middle of the car inside, i have been after one how much etc cheers Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted January 20, 2007 Share Posted January 20, 2007 Can also be used as a Harness bar too Ernie as I think the Do-luck sits above the carpet - so saves running a Harness bar in the car aswell. Harnesses should be run at an angle of 45 degrees from the back of the seat and not be connected directly down from the back. The harness bar is also produced to do just that and comes with struts to ensure that it does not move. Due to this, I would expect the harness bar to actually provide more rigidity improvements than the do-luck. Link to comment Share on other sites More sharing options...
Lebsteif Posted January 23, 2007 Share Posted January 23, 2007 Yes Carbing also make these, I haven't supplied any of these yet, so I'm not sure what improvement they make. [qimg]http://www.okuyama-go.to/products/floor/image/240/1000140.jpg[/qimg] Bumpski, i forgot this topic. Nic, Can you check the prices for the braces please. The bar for under the car and in the middle Do luck sale them in two flavours, aluminium and steel, what will the Carbing on will be? Link to comment Share on other sites More sharing options...
Lebsteif Posted January 24, 2007 Share Posted January 24, 2007 Kick Link to comment Share on other sites More sharing options...
