Guest Terry S Posted June 2, 2004 Share Posted June 2, 2004 Agree, single kits will help. The Blitz LM that Paul E is selling seems like a great offer. Quote Link to comment Share on other sites More sharing options...
Dragonball Posted June 2, 2004 Share Posted June 2, 2004 Originally posted by Terry S but why is 950 good. . Because it's not 1000! And this is at 1.35bar And well within the capacity of the plugs etc! And fuelling is good! FMIC works! The 'horror' stories of high EGT's is therefore patently not the case with these Which is also good! Which means they are still a very attractive viable option to stock (or single) where insurance and cost may be an issue! Hoorah! Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 2, 2004 Share Posted June 2, 2004 900 is good, 950 is as high as you'd ever want to go. The "horror" stories are true, 1000degC+ means things aren't right and eventually the engine will fall apart. I still think hybrids are a viable upgrade too though, if (like everything else) done correctly. And it's 'fazed' not 'phased' -Ian Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 2, 2004 Share Posted June 2, 2004 which is my point, you are very near the danger zone even with the mods you have undertaken. Never mind you know best. Quote Link to comment Share on other sites More sharing options...
Roy Posted June 2, 2004 Share Posted June 2, 2004 Originally posted by Roy how do you know if the ERL system is actually working ? well ? Quote Link to comment Share on other sites More sharing options...
Dragonball Posted June 2, 2004 Share Posted June 2, 2004 Silly Scooby tried it on today on M3 ! Warm day - 1.32 Bar - 140 leps - EGT 920degrees - Oil 108 degrees Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted June 2, 2004 Share Posted June 2, 2004 when i get mine back going to fit a walbro, would it help as i am still on stock pump and injectors. and i would like to know how you can tell if the eater injection still working. would it be wise to get some better fuel if you using it at dragstrip. say like 106 cool blue or is it no good for stock ecu. think everyone knows you need to try run cool. Quote Link to comment Share on other sites More sharing options...
heckler Posted June 2, 2004 Author Share Posted June 2, 2004 Originally posted by Roy well ? I have the aquamist dash display, tell you when its running, and the flow rate. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 2, 2004 Share Posted June 2, 2004 I got hybrids fitted along with fmic warlbro = bigger injectors ,ive been told that once its set up at thor I can run 1.4bar safe when its hot and 1.5 when its cool is this a good idea? Quote Link to comment Share on other sites More sharing options...
Roy Posted June 3, 2004 Share Posted June 3, 2004 Originally posted by heckler I have the aquamist dash display, tell you when its running, and the flow rate. bugger - i don't have one of those. is there any way at all of knowing if the system is working other than check washer fluid levels? Quote Link to comment Share on other sites More sharing options...
heckler Posted June 3, 2004 Author Share Posted June 3, 2004 Originally posted by Roy bugger - i don't have one of those. is there any way at all of knowing if the system is working other than check washer fluid levels? There is, however it only tells you that the pump is running, not that there is actual water flow, very easy, conncet a light/led accross the two wires of the pressure swtich. The dash display indicated water flow, and at what rate. Quote Link to comment Share on other sites More sharing options...
Roy Posted June 4, 2004 Share Posted June 4, 2004 thank you kind sir - you're a star ! Quote Link to comment Share on other sites More sharing options...
heckler Posted June 4, 2004 Author Share Posted June 4, 2004 Originally posted by Roy thank you kind sir - you're a star ! Quote Link to comment Share on other sites More sharing options...
dude Posted June 4, 2004 Share Posted June 4, 2004 Originally posted by heckler Thought you were in far off climes !!!! Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
heckler Posted June 5, 2004 Author Share Posted June 5, 2004 Originally posted by dude Thought you were in far off climes !!!! Dude:flame Dev I am - we have a satilite link "we have the technology - anyone know how to work it??" Quote Link to comment Share on other sites More sharing options...
dude Posted June 5, 2004 Share Posted June 5, 2004 Originally posted by heckler I am - we have a satilite link "we have the technology - anyone know how to work it??" No action yet ????? Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
heckler Posted June 6, 2004 Author Share Posted June 6, 2004 Originally posted by dude No action yet ????? Dude:flame Dev action? out here, nope - it not a war zone out here at all - we're just monitoring what is happening in Iraq. Aircraft go flying, and i go to "work" when they land - if our cameras are broken... so far, been here a week, and nowt has broken. so much so, i'm of to the Intercontinental hotel in Doha for the day. But theres plenty of other "action" walking around here, if you catch my drift... Quote Link to comment Share on other sites More sharing options...
