SIMON LC Posted December 5, 2006 Share Posted December 5, 2006 Looking at changing my Cambelt over Xmas and the job does'nt look majorly complicated.Only problem I can see is special Toyota tool for holding crank pulley when undoing crank pully bolt.Anybody know of this tool or ways round it?Cheers for any help. Link to comment Share on other sites More sharing options...
ChrisSZ Posted December 5, 2006 Share Posted December 5, 2006 I do know of the tool but I don't know of ways around it (unless you have a manual transmission) - it may be possible to undo the nut by sticking a socket over it, resting a breaker bar against the chassis and turning the engine over on the starter (undo the HT lead first). If the job's been done before and some plum has used loctite you're gonna need a whole lotta force to get the nut off (after destroying two sockets we ended up welding a socket onto the nut and using a 4ft breaker bar to shift the bugger!!) Have fun :) Link to comment Share on other sites More sharing options...
Graham S Posted December 5, 2006 Share Posted December 5, 2006 And don't forget you'll probably need a puller to get the pulley off! You'll more than likely struggle to get it off without one! Have fun! Link to comment Share on other sites More sharing options...
dini_the_owl Posted December 5, 2006 Share Posted December 5, 2006 hi mate, the best way around it i think if you have a manual is put it in 1st gear and put handbrake on and it should come loose quite easy,youll definately need a puller to get it off as its held in by a key,it will only go back on in one position to allign with the key so you cant get it wrong,just make sure you allign the marks on the pulley to the marks on the casing (check the 1st piston is at firing stroke) else it can be 180 out on the pulley and remove it. youll have to put it neutral after cause you dont want it to move the crank,the best way really is lock up the flywheel on the gearbox side that way it definately wont move,if youve got an auto box its gonna be a pain in the ass. Link to comment Share on other sites More sharing options...
Scooter Posted December 5, 2006 Share Posted December 5, 2006 You need a piece of 4-5mm thick, by about 30-40mm wide and 21/2 to 3 ft long steel and someone who can drill holes in it for you...........i can supply dimension details if you need them.... There was a guy willing to send his out to people wanting to do thier own.......i'll do a search......... Link to comment Share on other sites More sharing options...
markssupra Posted December 5, 2006 Share Posted December 5, 2006 You need a piece of 4-5mm thick, by about 30-40mm wide and 21/2 to 3 ft long steel and someone who can drill holes in it for you...........i can supply dimension details if you need them.... There was a guy willing to send his out to people wanting to do thier own.......i'll do a search......... Twas meee! Did have a pdf file of the tool somewhere, must be at work, post it up tomorrow. Link to comment Share on other sites More sharing options...
Scooter Posted December 5, 2006 Share Posted December 5, 2006 Twas meee! Did have a pdf file of the tool somewhere, must be at work, post it up tomorrow. there you go Simon and in case you miss it, theres a very detailed 'how to' in a link in Marks signature........ Link to comment Share on other sites More sharing options...
SIMON LC Posted December 6, 2006 Author Share Posted December 6, 2006 Cool guys.Yes forgot to mention I got a pain in the Ass auto so dimensions for special tool would be spot on ,cheers. Link to comment Share on other sites More sharing options...
Ric Posted December 6, 2006 Share Posted December 6, 2006 isnt it done upto about 350lb/ft too? ouch, lol. Link to comment Share on other sites More sharing options...
uk-rich Posted December 6, 2006 Share Posted December 6, 2006 i have the crank tool and the jacking gear, home made, you are welcome to borrow it but due to its size and weight you would have to collect it Link to comment Share on other sites More sharing options...
markssupra Posted December 6, 2006 Share Posted December 6, 2006 PDF file of the tool I made to lock crank pulley. If you want to borrow it I can post it for £10. Post it back to me when your finished.Crank Pulley Tool Model.pdf Link to comment Share on other sites More sharing options...
dini_the_owl Posted December 6, 2006 Share Posted December 6, 2006 hi rich were abouts are you situated in derbyshire? andy Link to comment Share on other sites More sharing options...
SIMON LC Posted December 6, 2006 Author Share Posted December 6, 2006 Cheers Mark thats very good of you,I may just take you up on the offer.I will let you know thanx mate. Link to comment Share on other sites More sharing options...
uk-rich Posted December 6, 2006 Share Posted December 6, 2006 hi rich were abouts are you situated in derbyshire? andy stones throw from east mids airport (kegworth) Link to comment Share on other sites More sharing options...
Rob Posted December 7, 2006 Share Posted December 7, 2006 PDF file of the tool I made to lock crank pulley. If you want to borrow it I can post it for £10. Post it back to me when your finished. Doh, I spent ages photographing and measuring your tool so I could make my own set. I've nearly finished it but I can't find a suitable disc of metal. It's all salvaged goods you see. Link to comment Share on other sites More sharing options...
markssupra Posted December 7, 2006 Share Posted December 7, 2006 Doh, I spent ages photographing and measuring your tool so I could make my own set. I've nearly finished it but I can't find a suitable disc of metal. It's all salvaged goods you see. Hope my tool measured up to your expectations Rob I could sell you a suitable disc of material See if any local engineering firms have any, might even have a piece in their skip Link to comment Share on other sites More sharing options...
Rob Posted December 8, 2006 Share Posted December 8, 2006 Oh believe me, I've been in more skips than a wino recently. I've got loads of discs but the centre holes are all too big. Some local bloke wanted £40 to make a disc then he started on with "nah mate, you don't want to mess about, just stick a screwdriver into the flywheel" Yeah, right. Link to comment Share on other sites More sharing options...
