cookci Posted November 19, 2006 Share Posted November 19, 2006 looks like my cars knackered. its used 2 pints of water in 3 month... TBH i havent been checking the water very often but after not checking for a long period its gone down... the car does smoke a bit (white smoke) but would that be the cold or the decats? whats the likely cause? i cant see any leaks and had the car idleing for a hour and its not gone down or leaked? please advise? Quote Link to comment Share on other sites More sharing options...
cookci Posted November 19, 2006 Author Share Posted November 19, 2006 also ive noticed recently when cold if i rev sometimes the revs drop very very low for a second or 2 after I let my foot off the accelerator then pick back up. when warm it runs fine! Quote Link to comment Share on other sites More sharing options...
cookci Posted November 19, 2006 Author Share Posted November 19, 2006 can anyone host a file showing what comes out the back? the coolant system doesnt seem over presured or anything like that either Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted November 19, 2006 Share Posted November 19, 2006 also ive noticed recently when cold if i rev sometimes the revs drop very very low for a second or 2 after I let my foot off the accelerator then pick back up. when warm it runs fine! SNAP ! Mines doing the same , What is this . Quote Link to comment Share on other sites More sharing options...
Scooter Posted November 19, 2006 Share Posted November 19, 2006 looks like my cars knackered. its used 2 pints of water in 3 month... what your rad cap like? whats the condition of the rubber on the plunger bit? Quote Link to comment Share on other sites More sharing options...
Guest V300 Posted November 19, 2006 Share Posted November 19, 2006 By way of reply I am here to relate my own mysterious coolant leak story. My twin turbo was loosing coolant erratically from the rad' and resevoir. There was no pattern to it, and no apparent sign of a leak. After a precautionary replacement of some coolant hoses, the coolant level was still dropping, and still with no apparent pattern. Sometimes the car would loose a litre after 200 miles and then again, it could hold the same level for up to a 1000 miles. Eventually, the radiator cap was diagnosed as the problem. The problem was not the main spring on the cap, it was the return valve. It was failing to seat properly, and due to the coolant not being pressurised, it was boiling out of the car's cooling system. If your radiator hoses are not ROCK SOLID after a 10 mile run, replace your rad' cap. In fact, I was told that that the Toyota radiator cap should be changed about every four years, due to this so called "known" problem. It seems that many blown Toyota head gaskets can be directly attributed to this problem. Quote Link to comment Share on other sites More sharing options...
cookci Posted November 19, 2006 Author Share Posted November 19, 2006 but what about the white smoke coming out the back? is this due to the cold weather and/or decat? the radiator cap SEEMS fine? im not sure what the rubber plunger bit is lol? Quote Link to comment Share on other sites More sharing options...
CJ Posted November 19, 2006 Share Posted November 19, 2006 99% certain the white smoke on start up will be condensation. Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted November 19, 2006 Share Posted November 19, 2006 yeah its just the cold mine does it whenever i start it up the next morning for a while until its warmed up. nothing to worry about Quote Link to comment Share on other sites More sharing options...
bowk1uk Posted November 19, 2006 Share Posted November 19, 2006 try the rad cap, i had the same problem, the little piece of rubber was missing of the end Quote Link to comment Share on other sites More sharing options...
cookci Posted November 19, 2006 Author Share Posted November 19, 2006 I had it idleing for almost an hour though and it was still smoking?!?!? thanks for all your help btw p.s. where do I get a rad cap from? thanks! Quote Link to comment Share on other sites More sharing options...
bowk1uk Posted November 19, 2006 Share Posted November 19, 2006 try mvp or envy performance Quote Link to comment Share on other sites More sharing options...
mr lover Posted November 19, 2006 Share Posted November 19, 2006 or toyota Quote Link to comment Share on other sites More sharing options...
JohnA Posted November 19, 2006 Share Posted November 19, 2006 If the new rad cap doesn't fix it, get a sniff-test done. Peace of mind in case it's more serious. Quote Link to comment Share on other sites More sharing options...
silvershark44 Posted November 20, 2006 Share Posted November 20, 2006 cool ill bear this in mind Quote Link to comment Share on other sites More sharing options...
Nic Posted November 20, 2006 Share Posted November 20, 2006 I had it idleing for almost an hour though and it was still smoking?!?!? thanks for all your help btw p.s. where do I get a rad cap from? thanks! Try a new rad cap and coolant flush first. If you need a rad cap I have TRD 1.3kgf/cm2 rad caps in stock for £18.50 each including postage. http://trdparts.jp/english/parts_radi-cap.html Quote Link to comment Share on other sites More sharing options...
cookci Posted November 20, 2006 Author Share Posted November 20, 2006 im going to go try get one today... if i cant then ill order one is this one coming from HK nic? how long will it take? Quote Link to comment Share on other sites More sharing options...
M4RK RZ Posted November 20, 2006 Share Posted November 20, 2006 but what about the white smoke coming out the back? is this due to the cold weather and/or decat? the radiator cap SEEMS fine? im not sure what the rubber plunger bit is lol? SNAP too ! Its just condensation mate, dont worry Quote Link to comment Share on other sites More sharing options...
Nic Posted November 20, 2006 Share Posted November 20, 2006 is this one coming from HK nic? how long will it take? Yes from here in HK, postage would take 5-7 days. Quote Link to comment Share on other sites More sharing options...
cookci Posted November 20, 2006 Author Share Posted November 20, 2006 panic over hopefully then its just the radiator cap I take it HG failure isnt too common on the supras then? Nic... thats a good price ill take it... how do you want paying? cheers christian Quote Link to comment Share on other sites More sharing options...
Nic Posted November 20, 2006 Share Posted November 20, 2006 Christian I have pm'd you payment details. cheers Quote Link to comment Share on other sites More sharing options...
cookci Posted November 20, 2006 Author Share Posted November 20, 2006 payment sent thanks mate Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted November 20, 2006 Share Posted November 20, 2006 But what about the low idleing when the cars cold ?? Quote Link to comment Share on other sites More sharing options...
