CJ Posted November 13, 2006 Share Posted November 13, 2006 Lara has just rang me to say that she is sat in her car and the key fob button to allow her to start the car is not working. I suspect it is a duff battery. Can she override it? It is a Clifford alarm if that makes any difference. Link to comment Share on other sites More sharing options...
Kopite Posted November 13, 2006 Share Posted November 13, 2006 New battery in the fob might be needed but maybe ring Matt Harwood mate for any other tricks Link to comment Share on other sites More sharing options...
Pete Posted November 13, 2006 Share Posted November 13, 2006 If she's lucky a battery will be ok. Shouldn't need to resync with the alarm. Only way to override is if she has the pin number to type into the doobry. Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted November 13, 2006 Share Posted November 13, 2006 point it as close to the dash as possible. Take out the battery and put it back in (works on my tv remote) Sorry, not much help. Link to comment Share on other sites More sharing options...
CJ Posted November 13, 2006 Author Share Posted November 13, 2006 Ring Matt Harwood mate I already have - and he just rang me back with advice Link to comment Share on other sites More sharing options...
Gazboy Posted November 13, 2006 Share Posted November 13, 2006 This happened to me- I jump started it with my other car. Link to comment Share on other sites More sharing options...
Kranz Posted November 13, 2006 Share Posted November 13, 2006 Col, is this the immobiliser fob that plugs into the dash socket??? Or the remote central locking fob?? Link to comment Share on other sites More sharing options...
CJ Posted November 13, 2006 Author Share Posted November 13, 2006 Col, is this the immobiliser fob that plugs into the dash socket??? Or the remote central locking fob?? I think it is the remote fob that she uses to lock the car. That also acts as an ignition starter when you turn on the ignition - if that makes sense. Link to comment Share on other sites More sharing options...
Gazboy Posted November 13, 2006 Share Posted November 13, 2006 Oh, I thought you meant the car batetry for some dumb ass reason, just ignore me- oh, you have already... lol. Link to comment Share on other sites More sharing options...
Pete Posted November 13, 2006 Share Posted November 13, 2006 Oh, I thought you meant the car batetry for some dumb ass reason, just ignore me- oh, you have already... lol. Phew! I was a bit worried there thinking you overcame the Clifford alarm by jump starting the car! Link to comment Share on other sites More sharing options...
Oly Posted November 13, 2006 Share Posted November 13, 2006 take the small battery out and turn it round - if its on its way out this usually works Link to comment Share on other sites More sharing options...
CJ Posted November 13, 2006 Author Share Posted November 13, 2006 Apparently, she has got a new battery but it still doesn't seem to be working. I have asked one of the Yorkshire lads if they can help her out. Link to comment Share on other sites More sharing options...
RedM Posted November 13, 2006 Share Posted November 13, 2006 She has the white 6speed, am I right? Link to comment Share on other sites More sharing options...
CJ Posted November 13, 2006 Author Share Posted November 13, 2006 She has the white 6speed, am I right? Yes, that is she - but maybe not for long as she has decided that it may have to go. Link to comment Share on other sites More sharing options...
RedM Posted November 13, 2006 Share Posted November 13, 2006 Is it a system where the car will start without needing the fob as long as it's started with 20-30 seconds? Link to comment Share on other sites More sharing options...
Kranz Posted November 13, 2006 Share Posted November 13, 2006 Is it a system where the car will start without needing the fob as long as it's started with 20-30 seconds? Mine has that Martin. Normally you can open the doors using the keyfob blipper thing & start the engine. If you take more than 30 seconds to start it re-immobilises & the lozenge thingy needs to be stuck into the dash bit. I'm on form with technical descriptions tonight!! Link to comment Share on other sites More sharing options...
CJ Posted November 13, 2006 Author Share Posted November 13, 2006 Is it a system where the car will start without needing the fob as long as it's started with 20-30 seconds? No, I think it needs the fob to allow the car to start after the ignition is switched on. Link to comment Share on other sites More sharing options...
RedM Posted November 13, 2006 Share Posted November 13, 2006 Mine has that Martin. Normally you can open the doors using the keyfob blipper thing & start the engine. If you take more than 30 seconds to start it re-immobilises & the lozenge thingy needs to be stuck into the dash bit. I'm on form with technical descriptions tonight!! Yeah, you turn the ignition on, press the button, a couple of lights come on and then you turn the key the last little bit. It doesn't work if the car is in gear though, I think! Link to comment Share on other sites More sharing options...
Guest lara Posted November 14, 2006 Share Posted November 14, 2006 Ha - belive me its not in gear I dont even know who can fix things like that - might have to hit the yellow pages - lol Link to comment Share on other sites More sharing options...
Daston Posted November 14, 2006 Share Posted November 14, 2006 try Hickly Valtone (not sure if they are a big franchise over the rest of the UK) Link to comment Share on other sites More sharing options...
Guest lara Posted November 14, 2006 Share Posted November 14, 2006 Ok thanks - will do. Link to comment Share on other sites More sharing options...
lockys96 Posted November 14, 2006 Share Posted November 14, 2006 i think your alarm has just pantsed up. mine did it. i locked it and came back and could not open with the clifford key fob. you can overide the car if you know what your 4 digit code is. you should have a code on the back of the key fob, and should have some buttons where you can enter the code in. i had to have mine reset Link to comment Share on other sites More sharing options...
