CJ Posted September 25, 2006 Share Posted September 25, 2006 Why is it that after driving with AC on you get a leak (looks like water) from the AC system. It has done it with every type of car I have owned. Link to comment Share on other sites More sharing options...
jamesmark Posted September 25, 2006 Share Posted September 25, 2006 It frost's up and then it melts and drips off. I think as it gets so cold that the moisture freezes Link to comment Share on other sites More sharing options...
stuohy Posted September 25, 2006 Share Posted September 25, 2006 Cos it removes it from the air, and has to put it somewhere... Link to comment Share on other sites More sharing options...
wkdtime Posted September 25, 2006 Share Posted September 25, 2006 AC evaporator drain. Link to comment Share on other sites More sharing options...
Rayman Posted September 25, 2006 Share Posted September 25, 2006 The same way when you pour a glass of ice cold water you always get moisture attached to the outside of the glass. Link to comment Share on other sites More sharing options...
Guest mk47 Posted September 25, 2006 Share Posted September 25, 2006 sorry cant help you there cj Link to comment Share on other sites More sharing options...
Kranz Posted September 25, 2006 Share Posted September 25, 2006 Cos its better than your feet getting wet (which is what would happen if the evaporator drain got blocked) Link to comment Share on other sites More sharing options...
CJ Posted September 25, 2006 Author Share Posted September 25, 2006 This is what I love about our forum. So much help and information. Thanks folks Link to comment Share on other sites More sharing options...
peter richards Posted September 25, 2006 Share Posted September 25, 2006 same as a fridge i think col, only the condensate in the fridge drops down onto the motor and evaporates Link to comment Share on other sites More sharing options...
Rob Posted September 26, 2006 Share Posted September 26, 2006 Why then did I get a huge cloud of vapour erupt into the cabin as I bombed along the A1 during that heatwave we had last month? Link to comment Share on other sites More sharing options...
edd_t Posted September 26, 2006 Share Posted September 26, 2006 that explains a lot! for ages ive been looking for a leak under my GF's Golf! she users the AC all the time, so that must be whats causing the water. Link to comment Share on other sites More sharing options...
Kranz Posted September 26, 2006 Share Posted September 26, 2006 Why then did I get a huge cloud of vapour erupt into the cabin as I bombed along the A1 during that heatwave we had last month? Cos when you have the air con switched on & its working it collects moisture on the evaporator, which cools the air that's going past it into the cabin. At full throttle it will switch off to allow more power (like we haven't got enough) to go to the wheels. When it switches off, the evaporator warms up & all that lovely moisture gets picked up and blown out of the vents onto the windscreen. That's why when you turn the air con off the air out of the vents gets smelly and damp. Link to comment Share on other sites More sharing options...
Supragal Posted September 26, 2006 Share Posted September 26, 2006 Why then did I get a huge cloud of vapour erupt into the cabin as I bombed along the A1 during that heatwave we had last month? This happened SO MUCh in Italy, but it was on the 1 day it threw it down with torrential rain. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted September 26, 2006 Share Posted September 26, 2006 Why then did I get a huge cloud of vapour erupt into the cabin as I bombed along the A1 during that heatwave we had last month? that sounds like the gas?? Link to comment Share on other sites More sharing options...
Rob Posted September 26, 2006 Share Posted September 26, 2006 I may have passed some gas when it happened. I thought the engine had let go, it was only the complete lack of smell that stopped my panic. Link to comment Share on other sites More sharing options...
