Any tips for installing coilovers?
Bob
In a rare show of kindness and generosity, she who must be obeyed has allowed me to work on the car this weekend :)
One of the things I'm hoping to do is get my coilovers installed. It all looks fairly simple from the Toyota workshop novel, but I figure there's bound to be something that tends to scupper things and make a 4 hour job into a 24 hour job.
So does anyone have any tips or tricks for fitting? Please?
Drop links are a common gotcha if you try to remove them and they're tight. The Hex type sockets can thread easily - that's what happened to me.
Then get it properly setup after install by someone that know what they're doing with suspension (like Chris). It'll be a waste of time swapping it over otherwise.
Not only does this gentleman sing my set up praises, he even holds a water glass to my parched lips me when I am injured, and doesn't bemoan a long round trip to find me semi comatose. A friend indeed, thanks Pete ;)
There is a guide on here somewhere, will have a look for it. The biggest problem you will have is pushing the suspension arms down far enough to allow the struts to be removed/ swapped over.
I used a scissor jack and some blocks of wood, sat the jack on the top suspension arm and wound the jack (with the blocks on top, pushing up against the inner arch) so it pushed the arm down untill it was down far enough to allow removal of the strut.
I'd say its the least safe of methods (the other involes the removal of the top suspension arm, I beleive) but it was (for me) the quickest. If you do use a scissor jack just keep checking that the jack is secure and at no risk of slipping at all before you try to remove the strut.
I always find quicker and more sympathetic to remove the top arms, there really isn't enough deflection in the bottom balljoint to allow the bottom arm to go down low enough when the upright is still held by the top wishbone. Watch the ABS sensor lead (remove the sensor form the upright), or you will be wondering why you have a fault code on the ABS..
  • 1 month later...
