Motec ECUs and Autoboxes????
Wez
Hey All,
Quick question for people running Motecs and autos, how does the Motec control the autobox or is the stock auto control left in place?
If its left in place how is the motec wired up and what is the motec actually controlling, just fuel and ign?
Thanks
On mine the stock auto control takes care of the box. The Motec is spliced into the stock loom I assume and it is controlling the fuel and ign. I can take a picture of the Motec install if and when I get a chance if you like.
Keep in mind that my response is a mix of information that I have been told and an educated guess by myself. It would be best for you to call Mark @ Owen Developments for complete clarification on this as they did the install.
The stock ecu controls the gearbox, the Motec does fuel and ignition and whatever other functions you choose to allocate and for which it has enough suitable outputs / inputs. It's probably possible to get an M800 to control the auto box, too, but it would be very time consuming and expensive to do the first such install and mapping.
OK my next question is if the motec can be setup this way to protect the autobox surely the AEM can as well.
Just wondering as AEM and auto do not have a great history.
To that I would say... It sounds so simple that it would have been done if it could have been. I suspect that there was a limiting factor and a difference in how the AEM and Motec are designed to run. Or at least with regards to accepting a piggyback control function.
That is my question :)
If the motec leaves autobox control down to the stock unit, why cant the AEM be setup the same way as people are worried about it blowing boxes up.
It can. AEM can be bought as a generic ECU with a full loom, so it can be fitted to any car , Just like the motec. It can be "piggybacked", Just no one as far as I know has done it because it sorta defeats the Plug and play option :). Might also be worth asking around on the auto issues as I'm lead to belive it's not a problem anymore.
http://www.aempower.com/ViewCategory.aspx?CategoryID=63
I didnt think it was an issue either as they introduced a shift retard option, but one mapper i know said its not used as it doesnt feel right when working.
Are there any UK based cars running AEM with autos and no issues?
Unfortunately the auto issue does not seem to have been catagorically overcome...
There are instructions on the AEM forum on how to undertake / programme the change / timing retardation - but this does not seem to have overcome the almost 'random' nature of some boxes going and others working...
This might have promise if it could be made to work...
God help me... I should be going the AEM Plug and Pray route for my auto after she has undergone her overhaul... I expect the time frame of my work is going to far exceed the time requirements for a sensible response in this case - with that mind though, I too would be interested in any answers to this thread.
TBH I agree with Wez. AEM is too easy a tool for amature mappers to get hold of and have a go, so it's inevetable that some bad results will come to light. Not saying that the AEM doesn't have any problems , it may well have, It's just I Heard through the grapevine that it's less of an issue than it was at the begining. I have also heard of random box failure with other ECM's on the auto and also success stories too. What would be nice, so this question stops coming up on a monthly basis, Is to get a Fully qualified AEM mapper, one that works AEM everyday to give his input and put this puppy to bed :) But I fear there isn't too many UK mappers qualified to give this input.
Well since the AEM is basically a Gems unit there are surely Gems mappers in the UK.
You would think so. How many are Savvy in the Supra auto department ;) I would say GEMS unit that has had a bit more fruit and veg added to it by AEM would be more PC.
So basically what we are saying is yes we could use an AEM to control all other aspects and use the stock unit for autobox control until the autobox control within the AEM is proven.
I guess the easiest way to wire this would be with a fields harness.
Dont bet on it, this has been rumbling on for years.
Err.. no I dont think so m8. This, and I may be wrong, is a new slant on the AEM question - in as much I cannot remember anyone mooting this as a 'piggyback' in this respect (as opposed to a standalone EMS)
If this is possible then in my book I would be much happier to look at this system again - whereas previously I had discounted it for the auto...
