TRD3000GT Posted March 15, 2004 Share Posted March 15, 2004 I have just got hold of one of these. Need to know how to install it? Any ideas? Where do I plumb the lines in to ? Also what exactly does it do, and how do I use it? Typical, It looked cool but now I have it dont know what to do with it? Link to comment Share on other sites More sharing options...
Digsy Posted March 15, 2004 Share Posted March 15, 2004 Chris, I would imagine that the two lines at the top connect from your camcover and to your intake system (i.e. inline with either the WOT or part throttle breather pipes). There should be a dirty great big oil drain from the bottom if its anything like the catch cans I'm used to. This will go to the oil pan. Just out of interest, do you suspect you actually have an oil carry-over problem? Link to comment Share on other sites More sharing options...
michael Posted March 15, 2004 Share Posted March 15, 2004 I've always fancied one of those myself, both bling and functional As I see it you can position it anywhere you like - all you need to do is remove the pipe that currently vents back into the engine and put the catch can inline instead - then as the air and oil droplets / vapours attempt to go back into the system they oil drops into the can leaving nice clean air to go back in. Every once in a while you take it off, empty the oil under a neighbours car and put it back in again. Link to comment Share on other sites More sharing options...
TRD3000GT Posted March 15, 2004 Author Share Posted March 15, 2004 Sounds cool, At the moment I dont have any oil problems but Im planning on some Mods that will benefit from these trick bits I have ordered. I just need to know where to hook up the pipes to ? Any pics people. Im taking the car to a frind of mine with a ramp and the two of us are gonna fit the unit :-) But I still dont know where to hook up the lines to. Link to comment Share on other sites More sharing options...
Nick Posted March 15, 2004 Share Posted March 15, 2004 There's quite a lot of info on Supraforums about catch tanks, just need a bit of time to read through it all and ignore the crap... Link to comment Share on other sites More sharing options...
Digsy Posted March 15, 2004 Share Posted March 15, 2004 Originally posted by mcanny Every once in a while you take it off, empty the oil under a neighbours car and put it back in again. You've gotta be joking! You mean it actually holds the oil in there and doesn't let it drain back into the sump? How much does it hold??? Link to comment Share on other sites More sharing options...
michael Posted March 15, 2004 Share Posted March 15, 2004 Originally posted by Darren Blake You've gotta be joking! You mean it actually holds the oil in there and doesn't let it drain back into the sump? How much does it hold??? Only a few of the aftermarket ones I've seen have the necessary pipework to drain back into the sump - the majority just collect the oil and require emptying - the Greddy is one of the few that offers a sight glass so you can check the level. I guess such a small amount of oil over a long period of time won't cause the engine to starve of lubrication, if it was collecting litres of the stuff I can understand it being an issue though Link to comment Share on other sites More sharing options...
Digsy Posted March 15, 2004 Share Posted March 15, 2004 OK, just to continue my role as devil's advocate here... If you are only pulling over a small amount of oil over a long time then there's no reason to fit a catch can - the stock closed breather system should easily be able to cope. If you are pulling enough oil over to warrant a catch can, surely it should really be the type that allows it to drain back into the pan? Link to comment Share on other sites More sharing options...
Ian C Posted March 15, 2004 Share Posted March 15, 2004 Never underestimate the power of Bling. Functionality comes a poor second Shiny metal battery cover, anyone? -Ian Link to comment Share on other sites More sharing options...
Sharpie Posted March 15, 2004 Share Posted March 15, 2004 Originally posted by TRD3000GT Any pics people. http://personal.tcu.edu/~blucas/supra/Engine-Right.jpg Link to comment Share on other sites More sharing options...
Terminator Posted March 15, 2004 Share Posted March 15, 2004 Originally posted by TRD3000GT Typical, It looked cool but now I have it dont know what to do with it? You sound addicted Bling Anonymous anyone:D Link to comment Share on other sites More sharing options...
Dragonball Posted March 15, 2004 Share Posted March 15, 2004 Originally posted by Terminator You sound addicted Bling Anonymous anyone:D Turn it into a catch tank! I loved the look - but no idea where or what to do with it! Story of my life! Link to comment Share on other sites More sharing options...
Sharpie Posted March 15, 2004 Share Posted March 15, 2004 This might be of use. http://www.supraforums.com/forum/showthread.php?s=&threadid=172203&highlight=oil+catch+can and http://cjsupra.kendra.com/PCV-Can.html The second one has the install instructions. Did you get the 9mm one as I have read that the 15mm is too big for our cars.......? let us know how you get on Link to comment Share on other sites More sharing options...
Wez Posted March 15, 2004 Share Posted March 15, 2004 The 15mm greddy one was recommended to me by Power House Racing as they no longer stock there own item. Link to comment Share on other sites More sharing options...
Wez Posted March 15, 2004 Share Posted March 15, 2004 The Mocal units are not bad either and also come in two sizes and look alot easier to mount :- http://www.demon-tweeks.co.uk/catalogue/product_detail.asp?PCODE=MOCCT3&GRP=RP063&PGRP=R006&CLS=ROAD&code=MOCCT2&from=search Link to comment Share on other sites More sharing options...
