Matt Harwood Posted August 3, 2006 Share Posted August 3, 2006 Yeah but the French are known to be weird Link to comment Share on other sites More sharing options...
Jezz Posted August 3, 2006 Share Posted August 3, 2006 In France it's called the Supra Bi-Turbo. Its cos it sucks and blows. So they think its bi-sexual. Link to comment Share on other sites More sharing options...
Alex Posted August 3, 2006 Share Posted August 3, 2006 Ah cheers for that link. Good read. So I'd name the Supra's turbo system as a Sequential Twin Turbo No Sh1t Sherlock. Sorry but you really do write like you're trying to teach us all how to suck eggs. Link to comment Share on other sites More sharing options...
Jezz Posted August 3, 2006 Share Posted August 3, 2006 Sorry but you really do write like you're trying to teach us all how to suck eggs. Can you teach me Alex. I've never sucked an egg before. Link to comment Share on other sites More sharing options...
chilli Posted August 3, 2006 Share Posted August 3, 2006 lol yes you would call it that because that is what it is! still a twin turbo though, no wool over anyones eyes there It does what it says on the tin Link to comment Share on other sites More sharing options...
imi Posted August 3, 2006 Share Posted August 3, 2006 So I'd name the Supra's turbo system as a Sequential Twin Turbo, not a true Twin Turbo - as in two independent exhaust systems feeding the turbos that happen to flow air at the same time. Though that would just confuse the fools with the money. Hmm.......Very interesting point.................... Naaaaaaaaaaaaaah I still think Toyota know best. Uninformed Link to comment Share on other sites More sharing options...
wkdtime Posted August 3, 2006 Share Posted August 3, 2006 Whats the problem?, i see 2 identical turbos, both came out the factory together, just like a ladie giving birth to two identical babies, so 'Twin Turbo' and thus 'Twin babies' and not 'Oh congratulations darling, you've just given birth to Bi babies' Edit: Damn im bored. Link to comment Share on other sites More sharing options...
Homer Posted August 3, 2006 Share Posted August 3, 2006 This raises the question though that if the turbos can run 0.8bar of boost as standard, then surely you can get them to run a potential total of 1.6bar inlet manifold pressure and not be overstressing the turbos (fueling/cooling permitted etc) albeit probably getting a boost drop off toward the redline? Yet I see reports of not to run more than 1.2bar boost as a guideline? Is it just not worth the risk? You really need to learn a little more about turbo systems. Have a search or if you're truely interested in answering your own questions order the books already suggested. Its twin turbo because the word mean "Being two or one of two identical or similar things:" I.e The 2 turbo's are identical. The wording of twin turbo's or otherwise has nothing to do with their operation. Link to comment Share on other sites More sharing options...
Keith C Posted August 3, 2006 Share Posted August 3, 2006 Twin and bi turbo are interchangable terms. Plus, the I'm pretty sure S4 is a parallel turbo system, with 2 identically sized turbos. Link to comment Share on other sites More sharing options...
matt k Posted August 3, 2006 Share Posted August 3, 2006 In the UK and the US it was referred to as a Mkiv Supra turbo although it does have 2 turbos, i think the point is it's turbochaged and even in stock form is pretty fooking quick! The fourth generation Supra was still powered by the familiar straight six engine. With the help of two turbos the Supra delivers a healthy 320bhp. The Mk IV Supra is no longer in production and it is still uncertain if it will be replaced. General specifications Record last updated Before 12 / 01 / 2004 Country of origin Japan Years of production 1994 - 2000 Numbers built N/A Body design N/A Weight 1642 kilo / 3620 lbs Drivetrain Engine Straight 6 Engine Location Front , longitudinally mounted Displacement 2.997 liter / 182.9 cu in Valvetrain 4 valves / cylinder, DOHC Fuel feed Fuel injection Aspiration Twin Turbos Gearbox 6 speed Manual Drive Rear wheel drive Performance figures Power 320 bhp / 239 KW @ 5800 rpm Torque 427 Nm / 315 ft lbs @ 4000 rpm BHP/Liter 107 bhp / liter Power to weight ratio 0.19 bhp / kg Top Speed 249 km/h / 155 mph 0-60 mph Acceleration 5.0 s Ferrari 456GT M Scaglietti Record last updated Before 12 / 01 / 2004 Country of origin Italy Year of introduction 2002 Introduced at 2002 Geneva Motorshow Numbers built N/A Body design Pininfarina Weight 1690 kilo / 3725.8 lbs Drivetrain Engine 65º V 12 Engine Location Front , longitudinally mounted Displacement 5.474 liter / 334 cu in Valvetrain 4 valves / cylinder, DOHC Fuel feed Bosch Motronic M5.2 Fuel injection Aspiration Naturally Aspirated Gearbox 6 speed Manual Drive Rear wheel drive Performance figures Power 442 bhp / 330 KW @ 6250 rpm Torque 550 Nm / 406 ft lbs @ 4500 rpm BHP/Liter 81 bhp / liter Power to weight ratio 0.26 bhp / kg Top Speed 300 km/h / 186 mph 0-60 mph Acceleration 5.0 s Resources Useful links - Official Ferrari site - Other cars by Ferrari - Suggest a site Link to comment Share on other sites More sharing options...
Jezz Posted August 3, 2006 Share Posted August 3, 2006 Whats the problem?, i see 2 identical turbos, both came out the factory together, just like a ladie giving birth to two identical babies, so 'Twin Turbo' and thus 'Twin babies' and not 'Oh congratulations darling, you've just given birth to Bi babies' Edit: Damn im bored. Congratulations madam, its sequential girls. Link to comment Share on other sites More sharing options...
JohnA Posted August 4, 2006 Share Posted August 4, 2006 Twin and bi turbo are interchangable terms. . When I was working in Brighton, lots of people around were bi but not twins. HTH:d Link to comment Share on other sites More sharing options...
imi Posted August 4, 2006 Share Posted August 4, 2006 When I was working in Brighton, lots of people around were bi but not twins. HTH:d Hey, my car is Twin...not Bi - thankyou very much.... Link to comment Share on other sites More sharing options...
chilli Posted August 4, 2006 Share Posted August 4, 2006 yeah and cars have twin exhaust and twin headlights too - not bi exhaust and headlamps. Call anything 'bi' on a members car and they are likely to get the knock lol Link to comment Share on other sites More sharing options...
