Graham Rudd Posted November 21, 2001 Author Share Posted November 21, 2001 Quote: from Doughie on 11:19 pm on Nov. 21, 2001[br]Graham Are you sure they're not just going to nick your code and save themselves some development costs ? cos that's theft (assuming you hjave intellectual copyright on your app or whatever). don't trust anyone when it comes to business and money. that's my advice. Well, it would be of limited use to them as I didn't send them the source code, just the exe. I'm WAY to trusting to suspect anyone of nicking anyway. Link to comment Share on other sites More sharing options...
Graham Rudd Posted November 22, 2001 Author Share Posted November 22, 2001 Quote: from Doughie on 10:31 pm on Nov. 21, 2001[br]hang on Graham. - i emailed Justin 2 days ago saying "i want a GPS - sort me a discount" and he sugeested (obviously) getting a group buy together. I ahve done some research into it. Looks like a Garmin Etrex or GPS12 or a Magellan unit. What's your preferred max. price ? I may post up a thread on GPS to see how much interest we can get. Bah! I managed to miss this post last night. If you could chase this up Stu, that would be fantastic. Justin! Are you listening? Not to sure how long I can resist the urge to just buy one though. Graham aka Mr. Impulsive Link to comment Share on other sites More sharing options...
Rich J Posted November 22, 2001 Share Posted November 22, 2001 Graham, can you make the trace on a seperate window that can be maximised in the release version rather than on the space on the dialog box? Also can you make it so when you open a dat file that it comes up with .dat in the files of type box, and I have a strange problem that when I use it on my main PC (Win98) it opens up in the My Documents folder rather than in the application folder. Minor stuff I know. (Edited by HardHead42 at 8:45 am on Nov. 22, 2001) Link to comment Share on other sites More sharing options...
Graham Rudd Posted November 22, 2001 Author Share Posted November 22, 2001 Quote: from HardHead42 on 8:40 am on Nov. 22, 2001[br]Graham, can you make the trace on a seperate window that can be maximised in the release version rather than on the space on the dialog box? Also can you make it so when you open a dat file that it comes up with .dat in the files of type box, and I have a strange problem that when I use it on my main PC (Win98) it opens up in the My Documents folder rather than in the application folder. Minor stuff I know. The actual data analysis window is seperated from the main dialog. The small data display shown in the screenshot is only used during real time capture. I guess I was just designing it from the way I would personally use the system, that is capture all of the data then check it out afterwards. Would people find it preferable for the actual data acquisition to also be in a 'normal' window? I.e. one that can be resized and made full screen etc. As to the file load/save/default location/extenstion stuff, yep no problem, I will sort it out. Thanks for the feedback. Graham Link to comment Share on other sites More sharing options...
Doughie Posted November 22, 2001 Share Posted November 22, 2001 Graham - any more news on why your 4 wheel traces are not all aligned exactly ? Phil - did you manage to check out the rear ABS sensor to see if it's the same tooth-count as the front one ? Link to comment Share on other sites More sharing options...
Phil Wall Posted November 22, 2001 Share Posted November 22, 2001 I hope to check this afternoon. Link to comment Share on other sites More sharing options...
Graham Rudd Posted November 22, 2001 Author Share Posted November 22, 2001 Ok, I've got the scroll and zoom feature working in the analysis window. I've examined a longer trace with a nice straight road drive section in it. The two rear wheels speeds match up with each other, as do the two front wheel speeds. So what I get on the trace is a distinct seperation between front and rear wheel speeds. On the face of it I guess this is correct, if the RL unit is just pumping out raw data. Link to comment Share on other sites More sharing options...
Doughie Posted November 22, 2001 Share Posted November 22, 2001 that shouldn't be happening. the traces should all coincide. Must be one of two things: 1) ABS sensors have different tooth count front to rear OR 2) (more likely) you've entered your Driven and Reference diameters wrong. By my calculations, they should be (assuming you didn't make a typo) : REAR (Driven) : 628mm FRONT (Reference) : 678mm (are you sure your rears are 30% profile??) (Edited by Doughie at 10:58 am on Nov. 22, 2001) Link to comment Share on other sites More sharing options...
Phil Wall Posted November 22, 2001 Share Posted November 22, 2001 I guess I was just designing it from the way I would personally use the system, that is capture all of the data then check it out afterwards. Would people find it preferable for the actual data acquisition to also be in a 'normal' window? I.e. one that can be resized and made full screen etc. A sizable window would be very useful for realtime in car monitoring. Link to comment Share on other sites More sharing options...
Phil Wall Posted November 22, 2001 Share Posted November 22, 2001 Quote: from Doughie on 10:56 am on Nov. 22, 2001[br]that shouldn't be happening. the traces should all coincide. Must be one of two things: 1) ABS sensors have different tooth count front to rear OR 2) (more likely) you've entered your Driven and Reference diameters wrong. By my calculations, they should be (assuming you didn't make a typo) : REAR (Driven) : 628mm FRONT (Reference) : 678mm (are you sure your rears are 30% profile??) (Edited by Doughie at 10:58 am on Nov. 22, 2001) It may be worth checking manufacturer data as this often differs from calculations made using side wall data. If it is the rear wheel teeth, any one hazard a guess before I count them!!!! Link to comment Share on other sites More sharing options...
Graham Rudd Posted November 22, 2001 Author Share Posted November 22, 2001 Has anyone got a trace from the traclog.exe that they could zip up and send to me? I want to check someone else's trace to see if I can figure out whats happening. Thanks Graham Link to comment Share on other sites More sharing options...
Doughie Posted November 22, 2001 Share Posted November 22, 2001 Given that the rear and front traces on Graham's car are not radically far out, i would think it's the wheel diameters that are a bit out. A way to check the actual tyre circumference (and therefore calculate the diameter) is to use a metal tape to measure the centre-line of the tyre. (you could take the wheel off the car but not necessary - you can just jack the wheel up to get it off the ground to get the tape underneath). i've given up guessing on ABS sensors.... Link to comment Share on other sites More sharing options...
GavinL Posted November 22, 2001 Share Posted November 22, 2001 Quote: from Doughie on 11:48 am on Nov. 22, 2001[br]Given that the rear and front traces on Graham's car are not radically far out, i would think it's the wheel diameters that are a bit out. A way to check the actual tyre circumference (and therefore calculate the diameter) is to use a metal tape to measure the centre-line of the tyre. (you could take the wheel off the car but not necessary - you can just jack the wheel up to get it off the ground to get the tape underneath). i've given up guessing on ABS sensors.... Why not mark the tyre and the ground under with a peice of chalk, roll the car 1 wheel revolution forward, mark the ground again and measure.......jacking the car up sounds like hard work too me Link to comment Share on other sites More sharing options...
Doughie Posted November 22, 2001 Share Posted November 22, 2001 Gav you're a genius ! Link to comment Share on other sites More sharing options...
Phil Wall Posted November 22, 2001 Share Posted November 22, 2001 The rear sensor has 48 teeth as well, just checked. I guess it had to be, but I just had to be sure. I can't help with file Graham as my lap top will not connect with anything other than USB so no DOS communication. (Edited by Phil Wall at 5:15 pm on Nov. 22, 2001) Link to comment Share on other sites More sharing options...
Graham Rudd Posted November 22, 2001 Author Share Posted November 22, 2001 I've double checked my tyre profiles, I've definitely entered everything correctly. Guess I'll have to actually measure them to enter the exact data. Link to comment Share on other sites More sharing options...
Phil Wall Posted November 22, 2001 Share Posted November 22, 2001 If this system can spot the difference in tyre tread with in the 8mm to 2mm range, it is amazing. But when you think about it that is 37 mm difference in circumference( on a 17 inch wheel) between a new and a tire down to the 2mm bars. That is just over 2% difference. Possibly enough to fool the system into perceiving slip earlier or later than programmed. Link to comment Share on other sites More sharing options...
Graham Rudd Posted November 23, 2001 Author Share Posted November 23, 2001 Out of curiosity I took my car out this morning just to see if there were any adverse effects from my slight difference in front to rear wheelspeeds. Unfortunately there is, if I try pulling quite tight turns the RLTC will cut in, even thought the car is definately NOT slipping. Whats pretty irritating about this is that it would seem to indicate that the system is so sensitive, I guess a good thing, that to keep it in its best working order you're going to have to check your front and rear rolling diameters every now and then to compensate for tread wear. I was considering cheating by programming a calibration mode into the TC editor to automatically adjust either the front or rear diameter to compensate for this effect. i.e. get to a straight section of road, run the program, hit calibrate and drive down it for a few seconds. The system then comes up with revised tyre diameter parameters to bring the front and rear wheelspeeds in line with each other. On reflection, this probably isn't a good idea, more a cludge than a solution. Graham Link to comment Share on other sites More sharing options...
Phil Wall Posted November 23, 2001 Share Posted November 23, 2001 Graham, Which DAT file are you using, for your tests? We need someone with known, not calculated diameters to do the tight turn checks to see if we should recommend some setting alterations to enable less cut on non slip cornering situations. Link to comment Share on other sites More sharing options...
Graham Rudd Posted November 23, 2001 Author Share Posted November 23, 2001 Phil, Here is a copy of my active .dat file. Graham's DAT file Apologies for a mistake I made earlier, I said I had 245/45 front, they are 245/40. (However I had entered them correctly in the TC unit) Link to comment Share on other sites More sharing options...
Doughie Posted November 23, 2001 Share Posted November 23, 2001 Graham / Phil This situation is covered in the RL TC manual as supplied with the system. There is a troubleshooting section, and one of the issues is exactly the one GRaham is describing. The fix is also given. By memory (my RLTC manual is at home) to INCREASE both of the following two parameters *by* approximately "150" : "Min. Dif. in Wheelspeeds DRY" "Min. Dif. in Wheelspeeds WET" that should fix it. I will check the manual tonight but i believe that's what you need to do. My car does not cut out at all in tight turns. I really don't think that you need to re-set your wheel diameters. I would try jacking the car up & measuring them accurately with a metal tape measure. Link to comment Share on other sites More sharing options...
Graham Rudd Posted November 23, 2001 Author Share Posted November 23, 2001 Thats it, I'm going to make a conscious effort to actually read that damned manual! Link to comment Share on other sites More sharing options...
Doughie Posted November 23, 2001 Share Posted November 23, 2001 Graham just read your DAT file. I can tell you one thing that is WAY wrong : You have got your "Minimum RPM" set to 800 !!!!!!!! Change it to 2000 or 2500. this value is the minimum value, below which, cut does not happen. Stock value is 2000rpm. Martin Fahie and I are running 2500rpm. this could well be your problem with the car cutting in tight corners. (Your "Min.Dif. in wheelspeeds" seem fine). (Edited by Doughie at 12:59 pm on Nov. 23, 2001) Link to comment Share on other sites More sharing options...
Phil Wall Posted November 23, 2001 Share Posted November 23, 2001 Thanks just read it too, I agree with Stu. It may be worth knocking 25 off each wet and dry wheel speed difference figure as well, and keep going until it feels right. Martin has 100 lower on both of his settings. I am trying these settings at the moment. Link to comment Share on other sites More sharing options...
Graham Rudd Posted November 23, 2001 Author Share Posted November 23, 2001 Phil, Where did you get hold of manufacturer specific tyre data for rolling diameter? I've had a bit of a search, but its like trying to find a very small needle in a very big haystack. Link to comment Share on other sites More sharing options...
